-   -   Newest Uro windshield seal doesn’t fit very well (http://forums.pelicanparts.com/porsche-911-technical-forum/1009747-newest-uro-windshield-seal-doesn-t-fit-very-well.html)
175K911 10-07-2018 10:10 AM
Picked up a new Uro windshield seal from our host, after it was posted that all of the old seals had been purged and the only thing in inventory was the latest, most updated seal. Big gaps at both lower outer corners. Original glass and trim, just new seal. Had a professional glass installer do the work and he struggled for close to 2 hours trying to get it right. Got the right to look better but driver’s side is wide open. His opinion after 2 hours- this seal is junk. If I didn’t need to get the car done for the track I’d have taken the windshield back out and ordered a factory seal which of course would have meant paying for a second installation. Even after sitting outside in the sun for 3 days at the track, thinking maybe the rubber would relax and lay down, nothing changed. I think after my next track weekend, before putting the car in the garage for the winter, I’ll get a good seal and have it redone.
proporsche 10-07-2018 10:38 AM
Hi..there is plenty of info here on the forum..basically never buy uro windshield seal or any other brands...only original Porsche will fit correctly..
Ivan
76FJ55 10-07-2018 10:45 AM
Are you absolutely sure the lower section of seal is hooked correctly on the body? A "profesdional" windshield company spent at least 3 hours the first time trying to install the windshield in my 84 and got very close, but ended up tearing a section of the seal and had to order another one. On the second attempt it went worse and they eventually gave up and said they didn't want the job and told me to take it somewhere that specializes in 911s. It's very frustrating and I tried to help but they had already lost patience and wanted no help from me. At any rate I'd suspect the install before the seal. I of course could be wrong.
Koizumi 10-07-2018 10:49 AM
Even OEM doesn’t always fit! I’ve had 2 installed and both “slip” permanently. Very annoying especially in the rain.
Both were done by a vintage 911 and Ferrari expert shop. I think the car flexes over time just enough to cause permanent slippage. Really bothers me frankly!
proporsche 10-07-2018 11:04 AM
as i said above... all other seals from any brand will give you hard-times to install and it will never fit in corners..i went trough 3 different seals before i bought quite expensive Porsche factory seal.
And i know how to fit the windshield seal ....always do it by my self.
You will amazed how nice it fits.It is actually pre-shaped in all corners...so take my advice return the seal bite the bullet and get the original seal..
Ivan
OldSpool87 10-07-2018 11:30 AM
When I had my 930 painted I insisted on a Porsche seal which the shop proceeded to install upside down causing all sorts of fitment issues. Don’t rule out correct orientation.
proporsche 10-07-2018 11:44 AM
ED..show us some pictures of the seal
Ivan
walt 10-07-2018 12:03 PM
I've done mine twice. Both times I needed a second person on the outside to pull the lower corners out as I was pulling the rope from inside.
Jack Stands 10-07-2018 01:20 PM
I though URO had redesigned their seal for a better fit. Was this one the redesigned one?
Speed metal 10-07-2018 04:04 PM
Ive had a ton of grief with the latest Porsche seal too....
Koizumi 10-07-2018 04:09 PM
Yep! It’s ridiculous. It’s as if Porsche just made a mold of the faulty Uro gasket to fill inventory.
Speed metal 10-07-2018 04:27 PM
In fact, in the end an aftermarket one was used instead in my case. Just Bull*****. The aftermarket one was marginally better. I was really hoping the new URO one was going to be the fix. Ive read some good things about it:confused:
sugarwood 10-07-2018 06:00 PM
Recently had a windshield replaced on another marque, and the common wisdom was to only use OEM seals, unless you want to risk wind noise and reinstallation.
Johner 10-07-2018 06:52 PM
I bought the URO seal based on this review: http://forums.pelicanparts.com/porsche-911-technical-forum/998122-re-designed-new-uro-windshield-seal-review.html and was planning on installing this coming week.
I'm now in two minds as to whether to go ahead, but think that as shipping it back to Pelican from Canada will cost more than the seal, I'll probably go ahead and give it a try. I'll report back if it's successful or not.
ThomasTe 10-07-2018 11:39 PM
I always buy these. They have fitted correctly every time:
https://www.feboe.de/index.php/gummidichtungen-keder/id-911_541_225_03.html
175K911 10-08-2018 04:52 AM
To answer a few questions:
Yes, it was supposed to be the latest version of the seal. Just purchased 6 weeks ago, after all of the old stock was supposedly purged.
Yes, it is properly hooked at both lower corners. Just too narrow a seal to properly cover the gaps.
There was no bodywork done to the windshield ares, they were nice and rust free, just removed the windshield for full paint. Reused OE glass and trim. OE fit like a glove.
I still have the original seal, just didn’t think it was worth reusing after 30 years, but it fit well. I almost gave it to the glass guy and told him to use that instead.
Tonight I get to try installing the quarter windows, which is going to be a pain with roll cage tubing in the way. Hopefully being Lexan windows with NACA ducts and new factory seals it won’t be horrible, at least I dont have to worry about breaking the glass.
76FJ55 10-08-2018 05:11 AM
Is the windshield still installed? If so try to get a profile picture of how the seal lays against the body just behind the hindxhield wiper arms. The seal across this section of body should be forced into a concave shape it the windshield is seated fully.
175K911 10-08-2018 05:46 AM
http://forums.pelicanparts.com/uploa...1539002694.jpg
LIRS6 10-08-2018 06:08 AM
FWIW I had a repaint done last year, shop installed Porche seal on my '79, no issues - nice and tight
uwanna 10-08-2018 07:17 AM
Originally Posted by 175K911 (Post 10208718)
Have you tried this method? Worked for me.
Originally Posted by William930t (Post 3912956)
Tools needed are a rubber mallet and a shaped thin wedge of wood as shown
http://forums.pelicanparts.com/uploa...1209426595.jpg
Fit under trim and lightly tap toward the outer edges and watch the seal move!
http://forums.pelicanparts.com/uploa...1209426674.jpg
Duc Hunter 10-08-2018 08:24 AM
My car leaks like a sieve with the factory seal. The old URO seal leaked the same. I don’t have those gaps though. With the factory seal I can wash the car and have water dripping out from under the dash.
I think the factory seals are prob now made in china (like a lot of Porsche Classic parts seem to be now) and are crap too. I have not tried the new URO seal yet though.
Evans, Marv 10-08-2018 10:10 AM
My '72 leaked under the dash also. When I removed the windshield and the dash pad I had major rust to the metal under the dash corresponding to the bottom corners of the windshield.
UROParts 10-08-2018 10:12 AM
Hi Ed, could be wrong but looks like you have the old version seal. Please PM us a photo of the bag showing the label, if you still have it. We'll figure it out via PM. Perhaps someone returned an old version seal to Pelican and their warehouse staff returned it to stock for resale.
Here are photos of how the corners of the new seals look: http://forums.pelicanparts.com/porsche-911-technical-forum/998122-re-designed-new-uro-windshield-seal-review.html
Originally Posted by 3Ddesigns911 (Post 10055755)
Here are some pictures of the finished installation with the new seal and original windshield.
It is wider, and fits well all around including the corners. It molds around to the body and no gaps anywhere.
http://forums.pelicanparts.com/uploa...1527709506.jpg
Here's a photo showing the outer lip measurement to identify the redesigned version. OEM and our prior version have a lip that's about 8 or 9mm, while our redesigned seal is about 12mm. Also, you can't see it in the photo, but there's another rib hiding next to the inner lip for a total of four ribs, just like OEM. We discontinued the prior version of the seal around February of 2018.
http://forums.pelicanparts.com/uploa...1527898959.jpg
UROParts 10-08-2018 10:29 AM
That makes zero sense. We reproduced the OEM seal (which is logically the best approach), which means the problems with the OEM seal were also reproduced. Highly doubt Porsche would reproduce an aftermarket reproduction of their flawed OEM product. We are not and have never been the OEM supplier for this item.
However...it's entirely possible Porsche will eventually duplicate our new improved seal, or more likely will just buy our redesigned seal and repackage it as OEM. You'll know when the fitment of the OEM seal suddenly improves. :)
Koizumi 10-08-2018 11:29 AM
Perhaps so, but either way, none of these seem to appropriately fit. There’s always major gaps after a few days post install. Aesthetically it’s displeasing (which I could get over) but for a daily driver like me, the rain is the issue.
When was this new seal made? It’s been a year approximately since my last faulty purchase.
UROParts 10-08-2018 11:46 AM
We discontinued the prior version of the seal around February of 2018, so hopefully 99% of seals sold today are the new & improved version. Undoubtedly there are still a few of the old seals floating around out there, so we'll just have to handle them as they appear.
Hopefully anyone sitting on an old seal contacts us for exchange, instead of returning it to the retailer (where it could be resold) and then buying the new version.
175K911 10-08-2018 11:49 AM
First, thanks for your response.
Wish I had the original bag but I don't, got thrown out once the windshield was installed.
Purchased July 12 from our host. This is the p/n from the order- W0133-1618123-WPC. Was of the belief that all inventory had been sold through quite some time before that, but as you said, perhaps an old version that got returned and put back into inventory.
I agree by looking at the pics, especially the area over the windshield wiper humps, that the seal I got is quite a bit narrower than in your pics. I need to dig out my original Porsche seal and compare dimensions. But no matter what, I guess I'm looking at having to have the windshield pulled back out and reinstalled with a different seal to do it right. Car will likely never see rain, but since that's such a vulnerable area of the car, and mine is in excellent shape in there because the OE seal fit so well, it would be foolish to leave it like this.
SalParadise 10-08-2018 12:24 PM
Amazing to me that in 2018, what is essentially a re-sized VW Bug seal, that so many people still and will have problems.
Amazing that it's gotten that bad that all the seals are still cheese ball.
Canada Kev 10-08-2018 12:36 PM
Well, it IS such a highly advanced piece of technology, it's no wonder people have difficulty manufacturing a version that fits correctly... :rolleyes:
proporsche 10-08-2018 12:48 PM
I bought my front 911 windshield seal strait from Porsche dealer in Germany.and the outcome is perfect..before i had from SSF autopart OEM and from uro parts the older model....
It is for 1988-89 and 964 windshield....
before installation
http://img.pccreation.net/photos/201810082142085585.JPG
left top
http://img.pccreation.net/photos/201810082142322500.JPG
right top
http://img.pccreation.net/photos/201810082146205266.JPG
right bottom
http://img.pccreation.net/photos/201810082142451317.JPG
very happy with the Porsche made in Germany seal............ not Chines
uwanna 10-08-2018 01:02 PM
Here's a thread by Universeman that compares and contrasts the differences between Porsche and URO windshield seals. Nice piece of work! He shows the main differences between the OLD URO and Porsche
seal. Using his drawings you should be able to differentiate between an old vs newer style URO seal, particularly the number of seal ridges (3 vs 4) and the added seal lip on the new URO.
http://forums.pelicanparts.com/porsche-911-technical-forum/895087-detailed-differences-between-aftermarket-porsche-windshield-seals.html
universeman 10-08-2018 01:15 PM
The 964 seal (and windshield) are different from the pre-964 version, so not really an apples-to-apples comparison, though you can switch to a 964 windshield and seal if you want to get away from the metal trim and fitment issues.
Glad to hear about the longer lips on the URO seals. Many don't know about the role the trim plays in forming the seal; make sure you're educated on that before you condemn the seal itself. One thing I found when I did my test that Uwanna references above; besides an apparent difference in rubber quality and workmanship, there was not a difference in design concept between any of the seals. There are no pre-formed corners in the Porsche seal, for example. All of them hug the windshield the same way, and need to be held out by the functional trim, etc. Some may do better than others at stopping water ingress, but this is not due to an inherent difference in design; only a difference in execution.
The newer, wider seal from URO might do a better job at stopping water from getting into the channel, which is the reason any of the seals leak. It also will modify the appearance (slightly) of your car vs. an OEM seal due to the seal width. That may or may not matter to you.
proporsche 10-08-2018 01:40 PM
to universeman..quote..:There are no pre-formed corners in the Porsche seal"
the seal i have purchased has exactly this "preformed corners"...I have chosen the 964 seal and windshield because i was sick and tired to deal with the old trims and the not so perfect seals..
ivan
florio 10-08-2018 02:14 PM
To those that have leaky windshields, did you pump sealent between the gasket and the glass and the body? It's not glue as it never hardens (like butyl), and I thought that the factory did this, too.
uwanna 10-08-2018 02:22 PM
ivan
The preformed corners comments are about earlier seals, not '89 and
964 seals. Some earlier threads address the 964 windshied/seal as a proper replacement for the earlier ones, however some folks had a major problem as the '88 and earlier cars had a shorter metal mounting lip for the seal and the seal did not have enough purchase
on the metal lip to adequately secure the windshield.
Glad you had good luck with yours, but others have not been so fortunate.
mike monde 10-08-2018 02:43 PM
All I can add is that I just replaced my seal with the newer version and it solved my issue. The larger seal nicely covered the gap that was present with what I believe was a factory seal. My biggest issue was finding a windshield company who would do the job. Seems like vintage Porsche windshield installation isn’t high on the list in my area.
As suggested by UROparts, just make sure you have their new version. FYI, when I was ordering my concern was that Pelican was still stocking the old version so I found a vendor that guaranteed that they carried the newer version. (I do believe Pelican has updated their inventory)
I do believe the part number is slighly different so when ordering just confirm the newer part.
In the end I am very pleased with the fit of the URO product.
mepstein 10-08-2018 03:03 PM
There was a thread about reforming the aluminum trim into the corners with a piece of wood. I forwarded it to our body guy and he said the technique works great. Porsche also used a bit of sealant in the corners.
uwanna 10-08-2018 03:09 PM
Check my post #20 in this thread!
UROParts 10-08-2018 03:48 PM
I do believe the part number is slightly different so when ordering just confirm the newer part.
Thanks for your feedback Mike! The part number hasn't changed, so if anyone orders a new seal, compare it to the photos to make sure you received the new one. If you happen to receive the old version, we'll be happy to swap it out.
Trackrash 10-08-2018 05:43 PM
FWIW, this method is shown in the Porsche repair manual and usually it is required to get the best fit.
