-   -   Factory shift kit question (http://forums.pelicanparts.com/porsche-911-technical-forum/100990-factory-shift-kit-question.html)
UTKarmann_Ghia 03-06-2003 06:44 PM
I've been working on installing a factory short shift kit and I've been following the instructions on pelican. One thing they dont cover is which direction the box-type shifter holder goes. I dont know the official name, but it's the part where the retaining pin goes into and holds the shifter. It looks like a little rectangle with sides, but no top or bottom. Well, the original is symetrical, but the new one has a hump on it. Question is: is the hump up or down??? I installed it up, but I'm not sure if that's right.
PLEASE, ANYBODY!
turbo6bar 03-06-2003 07:21 PM
hump up
BGCarrera32 03-06-2003 08:24 PM
That part is called the "shift bell"
hump up
it's better when she's on top...:D :D :D
UTKarmann_Ghia 03-06-2003 09:12 PM
Yep, I took my best guess and placed the hump up :) (read your posts after). I figured that you want the pivot point higher than stock and that proved to be correct. Thanks guys.
