jamesjedi's Avatar
964 fuel pump in a 1979 3.0?
Silly question, I know.
I have a new 964 fuel pump. Can I use it on my 1979 3.0L. I am guessing not.
Old 10-16-2018, 05:37 AM
Don't know why you couldn't. I use the original 3.0 SC pump with the
964 3.6 transplanted into my '80SC. So the reverse should work as well, provided
it will bolt on correctly.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 10-16-2018, 05:52 AM
Bosch fuel pump ID number........
What is the Bosch ID number on the FP? I don’t see why you can not use it for your 3.0 liter motor. Could you post a picture of the FP? Thanks.
Tony
Old 10-16-2018, 05:56 AM
jamesjedi's Avatar
Old 10-16-2018, 07:40 AM
Bosch ID number.......
James,
You should have no problem using the above FP for your CIS. On the side of the FP is the Bosch ID number (0-580-254-xxx). I’ve been using these FP’s (-957, -967, -979, -984, etc.). What number is on the FP? Thanks.
Tony
Old 10-16-2018, 08:13 AM
jamesjedi's Avatar
Thanks for the reply.
I have; 0 580 464 058
Old 10-16-2018, 08:27 AM
Daugaard's Avatar
No, you can not.
It will go lean at full throttle.
964 are EFI and max. pressure are 5 bar your 3,0 are CIS and need 6,5 bar.
Daugaard
Old 10-16-2018, 02:33 PM
jamesjedi's Avatar
Makes sense. Thanks for the information. It is appreciated.
Old 10-16-2018, 02:36 PM
