-   -   Hard start 3.2 when warm... (http://forums.pelicanparts.com/porsche-911-technical-forum/1010273-hard-start-3-2-when-warm.html)
rolls 912 10-14-2018 04:11 AM
My 3.2 is difficult to start when warm. Any tips?
dfhtrhjn 10-15-2018 07:03 AM
Ya gotta give us more than that. Does it crank and no start, does it start and die, does it have trouble cranking?
Dmitry at Pelican Parts 10-15-2018 09:28 AM
As the member above stated, give us a few more details. Check out the link below to one of our site's DIY tech articles on the starter - it may help you troubleshoot.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/87-Starter_Troubleshoot/87-Starter_Troubleshoot.htm
rolls 912 10-15-2018 12:48 PM
Thanks. Yes it’s a bit light isn’t it.
Turns over like a champ hot or cold.
Cold start - few seconds of cranking and it comes to life nicely.
Hot start - it can take up ten seconds (sometime more)of cranking before it fires.
I strongly suspect it’s fuel related. Am I right in saying that the Carrera’s don’t have an accumulator?
jlex 10-15-2018 01:18 PM
Almost sounds like your system isn't retaining pressure when it's hot. I'd get a gauge and check pressure... could be a check valve on the fuel pump or a lazy injector that holding open after shut down (could be choking up on gas if one's leaking)
rolls 912 10-17-2018 12:14 AM
Okay - thanks for the heads up. I’ll start with the pump check valve.
proporsche 10-17-2018 01:53 AM
what was the last time you replace spark plugs and fuel filter?
Start with the basics.
Anything temperature related on 3,2 is your temperature head sensor on cyl number 3..
Ivan
jlex 10-17-2018 05:39 AM
I'd rather see you start with checking fuel pressure.... if the system retains fuel pressure after shut-down, then the check valve is okay.
