Always learning
Hard start 3.2 when warm...
My 3.2 is difficult to start when warm. Any tips?
Old 10-14-2018, 04:11 AM
Ya gotta give us more than that. Does it crank and no start, does it start and die, does it have trouble cranking?
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 10-15-2018, 07:03 AM
Administrator
Dmitry at Pelican Parts's Avatar
As the member above stated, give us a few more details. Check out the link below to one of our site's DIY tech articles on the starter - it may help you troubleshoot.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/87-Starter_Troubleshoot/87-Starter_Troubleshoot.htm
Old 10-15-2018, 09:28 AM
Always learning
Thanks. Yes it’s a bit light isn’t it.
Turns over like a champ hot or cold.
Cold start - few seconds of cranking and it comes to life nicely.
Hot start - it can take up ten seconds (sometime more)of cranking before it fires.
I strongly suspect it’s fuel related. Am I right in saying that the Carrera’s don’t have an accumulator?
Old 10-15-2018, 12:48 PM
Almost sounds like your system isn't retaining pressure when it's hot. I'd get a gauge and check pressure... could be a check valve on the fuel pump or a lazy injector that holding open after shut down (could be choking up on gas if one's leaking)
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 10-15-2018, 01:18 PM
Always learning
Okay - thanks for the heads up. I’ll start with the pump check valve.
Old 10-17-2018, 12:14 AM
proporsche's Avatar
what was the last time you replace spark plugs and fuel filter?
Start with the basics.
Anything temperature related on 3,2 is your temperature head sensor on cyl number 3..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-17-2018, 01:53 AM
I'd rather see you start with checking fuel pressure.... if the system retains fuel pressure after shut-down, then the check valve is okay.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 10-17-2018, 05:39 AM
