-   -   part # for 14 pin connectors? (http://forums.pelicanparts.com/porsche-911-technical-forum/1010365-part-14-pin-connectors.html)
spuggy 10-14-2018 09:45 PM
I know what the male/female 14 pins connector kits are (for the benefit of anyone searching, it's 911-612-113-05-M100 & 911-612-115-02-M100 respectively, both available from our host).
But does anyone have a part # or a source for the connectors themselves? I've got a full set of pins on the male relay panel side (together with an unused wire that goes where I want) and I simply want to add another female terminal to the plug...
Thanks!
timmy2 10-14-2018 10:18 PM
One female terminal Porsche Part # is 99965237612
Mercedes part # is 0045456628 (cheaper)
hotaru 10-15-2018 01:30 AM
timmy2
thanks for the info :)
do you know part# for pins only?
timmy2 10-15-2018 07:57 AM
Male pins?
No I don’t have a Porsche number.
I get them from the German mfg directly.
If you need one or 2, I have some good used ones.
PM me.
Edit: I think I did find a Porsche part number for the male pins at one time, they were $6 each..... also NLA IIRC.
spuggy 10-15-2018 08:24 AM
Awesome. thank you!
l_turn9 08-13-2019 08:04 PM
Hi Timmy, The 14 Connector on my 74 911 has gotten brittle with age and heat, do you still have any pairs of them around? I could use a pair if you do.... I have a short I think is starting in the 14 connector and thought I'd help myself by replacing the old parts while I'm at it...
Thanks,
LarryT
timmy2 08-13-2019 08:27 PM
Hey Larry,
Sorry I don’t have the plastic pieces, nowadays the only way to get the plastic pieces for the male connector is to buy the kit (or kits if you want both)in the first post.
And crappily, in the last year or so, they shrunk the depth on the male pin plastic top in the kit, making it a real bear to install.
Oh yeah, and prices for them have also gone up a lot....
l_turn9 08-14-2019 04:37 AM
Thanks Dennis!
