part # for 14 pin connectors?
I know what the male/female 14 pins connector kits are (for the benefit of anyone searching, it's 911-612-113-05-M100 & 911-612-115-02-M100 respectively, both available from our host).
But does anyone have a part # or a source for the connectors themselves? I've got a full set of pins on the male relay panel side (together with an unused wire that goes where I want) and I simply want to add another female terminal to the plug... Thanks!
'77 S with '78 930 power and a few other things. |
ROW '78 911 Targa
One female terminal Porsche Part # is 99965237612
Mercedes part # is 0045456628 (cheaper)
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 10-14-2018 at 10:45 PM.. |
timmy2
thanks for the info ![]() do you know part# for pins only?
----------------------------- '76 911 Carrera 3 - '81 911 coupe - '82 911 Targa - '83 911 Cabrio - '83 911 coupe (3.6 engine,964 body kit) - '86 911 coupe (ROW 3.2) |
ROW '78 911 Targa
Male pins?
No I don’t have a Porsche number. I get them from the German mfg directly. If you need one or 2, I have some good used ones. PM me. Edit: I think I did find a Porsche part number for the male pins at one time, they were $6 each..... also NLA IIRC.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 10-15-2018 at 10:05 AM.. |
Awesome. thank you!
Hi Timmy, The 14 Connector on my 74 911 has gotten brittle with age and heat, do you still have any pairs of them around? I could use a pair if you do.... I have a short I think is starting in the 14 connector and thought I'd help myself by replacing the old parts while I'm at it...
Thanks, LarryT |
ROW '78 911 Targa
Hey Larry,
Sorry I don’t have the plastic pieces, nowadays the only way to get the plastic pieces for the male connector is to buy the kit (or kits if you want both)in the first post. And crappily, in the last year or so, they shrunk the depth on the male pin plastic top in the kit, making it a real bear to install. Oh yeah, and prices for them have also gone up a lot....
Thanks Dennis!
