1969 911T Correct location for ballast resistor
Does anyone know the correct location for the placement of the ballast resistor on a 1969 911T? Thank you very much!
No, this car doesn't have CDI. It has conventional ignition. This is confirmed by a #12 stamped on the electrical relay panel on the left side of the engine bay.
The resister is in the coil, if you have the original coil.
| All times are GMT -8. The time now is 01:39 AM. |
