1969 911T Correct location for ballast resistor
Does anyone know the correct location for the placement of the ballast resistor on a 1969 911T? Thank you very much!
Old 10-15-2018, 11:01 AM
Jonny H's Avatar
If the car has a CDI box it should not have a ballast resistor. In fact, it will really screw up the ignition timing if there is one fitted.
www.classicretrofit.com
Old 10-15-2018, 11:22 AM
No, this car doesn't have CDI. It has conventional ignition. This is confirmed by a #12 stamped on the electrical relay panel on the left side of the engine bay.
Old 10-15-2018, 12:51 PM
The resister is in the coil, if you have the original coil.
206 637 4071
Old 10-15-2018, 02:09 PM
