targa weatherstrip install?
In process of reassembling a '72 targa after new paint, etc. Any good videos or instructions on putting new weatherstripping around targa bar, windshield and A pillars, etc??
I've done it to several 914's over the years, but the 911 looks very different! TIA
1971 914- original owner 1973 914 2.0 2018 911 carrera T 2016 981 Spyder PTS |
Eva
I've never done the seals around the glass, but have done the Targa bar.
I pre-fit a couple times dry just to get a feel for the process, then applied adhesive. Marked what seemed to be the center and worked my way out evenly to both sides. Came out mint
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
This post from this thread https://forums.pelicanparts.com/porsche-911-technical-forum/911180-anyone-know-how-adjust-window-frames.html may be helpful:
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-16-2018 at 06:05 PM.. |
Thanks! Seems like many adhesive holding the seals on the 911. The 914 has a metal frame that screws into the roll bar and the seals slide in.
Looks like I'll go thru a bit of rubber adhesive!
When I installed my rear top to bar seal it took a few tries to get it right.
This thread may be helpful. Targa seal install in Austin TX? Dan Petchel-recommended? This too https://forums.pelicanparts.com/porsche-911-technical-forum/981863-87-targa-bar-rear-seal-question.html
