lol. When I try to go to the page, it asks if I want to save it as a file...if that helps any. I am guessing netscape doesn't like the name of it or something, causing it to think it is a file and not a readable page.
It only happens if I try to go to that one page you set up as a redirect. |
If you have your cookies turned on, then you should have no problem. If you do have a problem, take a look at your cookies settings. Then again, if you didn't have a problem before, you shouldn't have a problem now. :)
-Wayne |
I just changed the headers - maybe that will help. I'm sure there is a quick fix in here somewhere - just haven't found it quite yet...
-Wayne |
Looks good Wayne! :D
I wanna be able to post using that bird....he's pretty cool.
Does this software allow us to put in our own message icon? |
Yes it does. The Pelican is resevered for me though. Check out the control panel under 'avatar.'
-Wayne |
Wayne,
Looks good so far. Thanks for all the effort you put into this stuff. I am anxiously awaiting the arrival of my signed copy of your book. One thing I must say is that I find GMT totally throws me off. PST or EST would definitely be better. Keep up the good work! :) |
That threw me too. You change to your local time in your control panel setting...
-Wayne |
| All times are GMT -8. The time now is 07:52 AM. |
