-   -   RSR Rear Quarterpanel fabrication (http://forums.pelicanparts.com/porsche-911-technical-forum/1010596-rsr-rear-quarterpanel-fabrication.html)
redline7500 10-17-2018 09:30 AM
I am creating a 73 RSR tribute from a donor 1970 race car. Part of the original quarterpanels were removed and fiberglass rear flares were installed with dzeus fasteners. I want to weld in steel quarterpanels and flares to accomodate the 18" rear tires that are 10 inches wide and eliminate the fiberglass quarterpanels. Does anybody know of a good shop in the Atlanta area that is set up to do this kind of work on Porsche's?
tdw28210 11-01-2018 04:57 PM
Not Atlanta, but just north of Charlotte. Actual "Panel Beaters" who can do this type of work ain't cheap.
Carolina Coach Crafters. https://www.carolinacoachcrafters.com/
Kraftwerk 11-01-2018 07:42 PM
RSR Steel Flares used to be readily available, no?
TheMetalSurgeon 11-03-2018 07:16 AM
thought about shipping it to Denver,Colorado? The Metal Surgeon 3037614884
jon@themetalsurgeon.com
i can give you an estimate if interested,thanks
lvporschepilot 11-03-2018 07:45 AM
Real deal steel RSR flares are available from one or two European suppliers. I’ve seen a front and rear set and they are stunning, hand made, and absolutely correct in shape and contour. They are very different than turbo flares. Getting them correctly butt-wielded to the quarter panels is the trick. I’ve done it myself for my car using RS flares and it is *not* easy and I know of know place in Atlanta area that will butt were them, only lap weld which is wrong. If you really want it done right, ship the car to the metal surgeon above.
rbogh901 11-03-2018 10:42 AM
Originally Posted by lvporschepilot (Post 10238144)
Real deal steel RSR flares are available from one or two European suppliers. I’ve seen a front and rear set and they are stunning, hand made, and absolutely correct in shape and contour. They are very different than turbo flares. above.
different contour or what exactly are the differences?
jamesjedi 11-03-2018 11:17 AM
They are made in Canada as well. The outer lip on the RSR flare "tends" to be more rounded. Here is a link. They are VERY expensive and currently out of stock.
2.8 RSR Fender flares, set of 4: Restoration Design Inc.
jamesjedi 11-03-2018 11:20 AM
RSR flare tended to have a more rounded lip. The 930 lip appears to be more square. There are many posts about them. They are made in Canada as well. Currently out of stock, VERY expensive.
Trackrash 11-03-2018 01:05 PM
Haven't some guys massaged turbo flairs to give the RSR look? I guess it depends on how authentic the OP wants to be.
TheMetalSurgeon 11-03-2018 03:07 PM
WOW $5600 plus shipping.....i need to start banging these out!!!
lvporschepilot 11-04-2018 05:28 AM
the EU suppliers aren't quite that high, around $4000 shipped would be about right.
metalracer 11-04-2018 07:23 AM
Wish you would......
TheMetalSurgeon 11-04-2018 12:37 PM
Anyone have a set i can loan ?
lvporschepilot 11-05-2018 04:10 AM
There's a company in the UK that actually has a stamping for them now. 3600 Sterling a set and they are spot on.
Jon, would a fiberglass one work? I might be able to rustle one up.
TheMetalSurgeon 11-06-2018 05:40 PM
It would,thank you .I could a hammer form from it.Would you know of the origin to research on accuracy feedback.Thank you for the offer.
