redline7500
RSR Rear Quarterpanel fabrication
I am creating a 73 RSR tribute from a donor 1970 race car. Part of the original quarterpanels were removed and fiberglass rear flares were installed with dzeus fasteners. I want to weld in steel quarterpanels and flares to accomodate the 18" rear tires that are 10 inches wide and eliminate the fiberglass quarterpanels. Does anybody know of a good shop in the Atlanta area that is set up to do this kind of work on Porsche's?
Old 10-17-2018, 10:30 AM
Cars and Cappuccino
tdw28210's Avatar
Not Atlanta, but just north of Charlotte. Actual "Panel Beaters" who can do this type of work ain't cheap.
Carolina Coach Crafters. https://www.carolinacoachcrafters.com/
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 11-01-2018, 05:57 PM
Kraftwerk's Avatar
RSR Steel Flares used to be readily available, no?
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 11-01-2018, 08:42 PM
Jon Bingham
Send a message via Skype™ to TheMetalSurgeon
thought about shipping it to Denver,Colorado? The Metal Surgeon 3037614884
jon@themetalsurgeon.com
i can give you an estimate if interested,thanks
Old 11-03-2018, 08:16 AM
Real deal steel RSR flares are available from one or two European suppliers. I’ve seen a front and rear set and they are stunning, hand made, and absolutely correct in shape and contour. They are very different than turbo flares. Getting them correctly butt-wielded to the quarter panels is the trick. I’ve done it myself for my car using RS flares and it is *not* easy and I know of know place in Atlanta area that will butt were them, only lap weld which is wrong. If you really want it done right, ship the car to the metal surgeon above.
Old 11-03-2018, 08:45 AM
Science is NOT optional
rbogh901's Avatar
Originally Posted by lvporschepilot View Post
Real deal steel RSR flares are available from one or two European suppliers. I’ve seen a front and rear set and they are stunning, hand made, and absolutely correct in shape and contour. They are very different than turbo flares. above.
different contour or what exactly are the differences?
PCA member since 1993
Old 11-03-2018, 11:42 AM
jamesjedi's Avatar
They are made in Canada as well. The outer lip on the RSR flare "tends" to be more rounded. Here is a link. They are VERY expensive and currently out of stock.
2.8 RSR Fender flares, set of 4: Restoration Design Inc.
Old 11-03-2018, 12:17 PM
jamesjedi's Avatar
RSR flare tended to have a more rounded lip. The 930 lip appears to be more square. There are many posts about them. They are made in Canada as well. Currently out of stock, VERY expensive.
Old 11-03-2018, 12:20 PM
Under the radar
Trackrash's Avatar
Haven't some guys massaged turbo flairs to give the RSR look? I guess it depends on how authentic the OP wants to be.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-03-2018, 02:05 PM
Jon Bingham
WOW $5600 plus shipping.....i need to start banging these out!!!
Old 11-03-2018, 04:07 PM
the EU suppliers aren't quite that high, around $4000 shipped would be about right.
No physical quantity completely explains its own existence
Old 11-04-2018, 06:28 AM
Wish you would......
Marc Zurlinden
zurlindengruppe.com
Old 11-04-2018, 08:23 AM
Jon Bingham
Anyone have a set i can loan ?
Old 11-04-2018, 01:37 PM
There's a company in the UK that actually has a stamping for them now. 3600 Sterling a set and they are spot on.
Jon, would a fiberglass one work? I might be able to rustle one up.
Old 11-05-2018, 05:10 AM
Jon Bingham
It would,thank you .I could a hammer form from it.Would you know of the origin to research on accuracy feedback.Thank you for the offer.
Old 11-06-2018, 06:40 PM
