Tune up interval advice
My last valve adjust / major tuneup was 3 years, 1 month, and 19,000 miles ago. Should I consider a valve adjust at this point, or is it safe to let it ride for awhile? Car is running like a top now. 1986 Carrera, currently at 172k miles. Thanks ...
Old 10-18-2018, 07:57 PM
HarryD's Avatar
My service intervals for my 911 are at multiples of 3,000.
every 3,000 - Oil/filter change
every 15,000 - Tune, valve adjust, transmission oil change, air filter, fuel filter etc.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-18-2018, 08:47 PM
Formerly known as Syzygy
Canada Kev's Avatar
I'd say it's time for a valve adjust at that mileage, but I tend to over-service. Keep in mind that your valves will likely get tighter over time rather than looser, which might not be terribly good.
I do mine about every two years or ~15 000 km on average (about 11 000 miles) and change the oil once a year except on those higher mileage years. However, I like Harry's system.
If you learn to do it yourself, you will likely get a good feeling from the exercise once complete. The first time will take you a day and some frustration until you get the hang of it, and the second time, half that. Subsequent adjustments will probably get even quicker.
Kevin
Old 10-18-2018, 09:35 PM
HarryD's Avatar
The only thing I would add is that for my cars using Synth oils, the interval is 5000 not 3000 miles.
And major services at multiples of 25000 miles.
Harry
2020 MB E350 4Matic
Old 10-19-2018, 07:18 AM
