Hi all,
This past spring I turned the key in my driver door lock, heard something give, and have not been able to unlock the driver side door from the outside since. I took the panel off to see if I could fix it without removing the window and could not. I determined I was going to have to dig in deeper but didn’t want to during the driving season. I can still lock/unlock from the inside, just not using the key on the outside so I've just been leaning across and locking it from the passenger side, then locking the passenger side door from the outside. Apart from being a pain in the butt, it is also embarrassing... With winter approaching I'm planning to take the door apart and see if I can fix it. I decided as long as I'm doing that, I might as well refresh my doors altogether, and of course I want to draw on the collective Pelican wisdom. So, here’s what I plan to do, and some questions for you:
Thanks to all in advance for guidance and input! My guess is around Christmas I’ll be back on here asking for help as I dig in! Todd |
Essentialist
My 911 is currently getting painted. I sure am interested in "sealing it" as it gets put back together. Would you please let me know about the book you mention?
Like father, like daughter 74 Targa Outlaw 60 Drauz Roadster Outlaw |
If you can post a photo of the lock I may be able to help as I have fixed lock problems on my car in the past.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
cycling has-been
Could be just the trigger in the handle assembly.
When you pull the trigger, what happens - can you still insert and turn the key? The trigger tab that is supposed to push the release rod into the door might just be broken off - it's only pot metal. Start looking for used handles for sale - the parts from the good one can be swapped into the old one - or have a locksmith do it. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Brap
That seems like the right list. Regrease locks and check felts.
@JSV798 and @bkreigsr here is the original thread I started earlier in the year. It has a pic of the inside of my door: Help with door lock problem... Thanks for any suggestions.
Your lock looks OK from that photo but I wonder if that post/pin on the end of the tumbler arm has sheared off and not moving with the key. I am assuming that the key moves back and forth? You may need to remove the handle (just two nuts as I recall) and check this out, although you may be able to watch what happens as you turn the key now that you have the door card off. I wouldn't think there's any need to strip down the whole door.
