911 sun roof delete report...how is it holding up
My '83 SC/w euro 930-10 will shortly go in for a full repaint....I am deciding what to mod.
It is already not stock...all sound deadening out..no back seats or deck just lightweight perlon...AC out...mirrors gone to Vitaloni's..console etc deleted...lots of little things that added up to some serious weight loss. Looking at glass front rear bumpers RSR style minus the front intake...I have a Carrera cooler in the front right wing. Would like to dump the sun roof....weight and simply because it is a half measure anyway. How have the Brit replacement panels with whatever filler you required held up over the years? |
I welded mine in. That was 1984. Still undetectable.
I'm guessing you are asking about the glued in version? IMO if you are going to the length of an entire paint job you may as well have a panel welded in. You already will need a new headliner which will require all the glass out. Then there is the metal work to remove all the bracing and tracks for the sun roof panel. |
Don't know which way I'll go...bonding or welding. |
Anyone here use ToddC's carbon fiber delete panel?
http://forums.pelicanparts.com/uploa...1540136740.jpg It's nice. I think he closed his business, so you may have to hunt for one now. It fit really well, but it had a rolled edge, which made it perfect for a track car plug with a roll bar. You could support it from underneath, do a basic finish of the edge of the roof and be done. Since I was doing a street car, I opted to sell the helion panel and weld in the uk panel. FWIW, I would just take the car to a hot rod metal guy and have them make a plug. It would save time, money and a lot of hassle. http://forums.pelicanparts.com/uploa...1540136999.jpg Mine is fresh, so nothing to report except for the fact that I'm ecstatic every time I LOOK at the roofline and every time I SIT inside the car. There is so much more space! I think it's my favorite mod. http://forums.pelicanparts.com/uploa...1540137373.jpg |
Or the Carbon fiber roof skin....that actually looks the easiest if a full paint job is in order...just got your note about Todd being out of business....your 911 look great btw....I know what you mean about the clean roof line...and the overhead inside clean look....the weight is key for me too...every pound gone helps.
This is quite frankly the most beautiful impact bumper car I have ever seen. Beautiful job!!
The sunroof is holding up well. If I had to do it over again (which, I actually am doing it over again on a different car) I would do a full roof skin. Not the easiest method, but results are much better - less filler, less chance of ghosting. Future episodes of my YT series will have the roof swap in detail. http://forums.pelicanparts.com/uploa...1583955871.jpg |
