'84 Carrera turn signal/ hazards weirdness
OK guys/girls..here's one that has me baffled. Hopefully someone has encountered a similar problem. The car is a 1984 Targa with 20,000 miles and in showroom condition. This morning while road testing I noticed the left front turn signal wasn't flashing, but the interior green arrow was brightly blinking at double speed. I used the hazard switch to check the other three signal lamps. They all flashed merrily, as did the interior indicators. Parking and head lamps well all good too, except the side markers. ..all four were blown. When I removed the non-flashing right front bulb it appeared to be fine..so I moved to the fuse box. There I found #8 fuse (I believe that was the number) to be bad, and replaced it. No problem one would think, right? Wrongo! Before reinstalling the left front lens' I flipped the signal lever to left and was greeted by a DIM green arrow flashing at normal speed. Outside the car neither left lamp worked at all...well the rear glowed very dimly while flashing. With hazard switch pressed all I got were interior green arrows blinking dimly. and super dim blinking exterior right side signals. With the replaced fuse removed right side signals work fine, hazards on that side work normally as well. What's really confusing me is that everything worked just fine until I replaced that bad fuse! HELP!!! Any ideas, thoughts, suggestions will be gratefully appreciated! The only upside is that least the side markers are working
What about the right side? Did they flash normally? Quote:
Find Spoke's LED Products: www.spokeworksled.com |
Do you ever get this sorted out? I just posted a very similar head-scratcher today that you might find less than amusing as well....
Paul '87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff. '96 993 cab (gone, oops); '82 SC (gone) |
