pokeytom's Avatar
Light Frustrations?
Need help please. All marker lights working. All but left front emergency flasher working. Bulb tested good. Installed new bulb same thing. Is my problem the flasher relay? This is frustrating
Thanks for the help
Old 10-25-2018, 07:24 AM
Have you checked that the ground is clean? I found in some instances that the little metal tabs that hold the bulb and act as ground had corroded. I removed them, sanded them up, and it fixed the problem.
_______________
John
1988 Carrera Targa 3.2 G50 - Sold.
2017 Chevy Silverado K1500.
Old 10-25-2018, 08:05 AM
Do all the turn signals work correctly, or do you have a failure of the left front turn signal as well as the flasher?
Old 10-26-2018, 08:15 AM
Did you ever get this figured out?
Paul
'87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff.
'96 993 cab (gone, oops); '82 SC (gone)
Old 12-30-2018, 09:07 AM
