Fuel Pump Refresh - 1971 911T Bosch Carburated Pump
After not driving my car for several months (needs synchros, another story), I pulled it out of the garage and it just started dumping gas on the ground.
Leaking from the pump, behind the rear driver's wheel.
As we know, this is comparatively a rare pump as it carburated low pressure with the return line. Porsche part number – 911.608.107.00 Bosch part number – 058096 0009 I would like to retain the return line as I believe it makes sense.
Based on forum posts, I called Fuel Injection Corporation in Livermore and they will indeed rebuild my pump for $325. This is a pretty good solution.
However, my pump works and it is such a simple design with just a leak, I am thinking about just replacing the seal under the pump lid.
Am I wrong to do this? Anybody else done similar?
Mine is squared off, but I suspect it was an o-ring before.
Anybody sourced an O-Ring?
Thanks a bunch!
Old 10-31-2017, 03:28 PM
there is earlier post here about rebuilding fuel pumps that had the sizes.
Lorne M.
83 SC
Old 10-31-2017, 08:32 PM
Fuel Pump Refresh
I have exactly the same issue. One pump spins but leaks, the other doesn't spin. I have not been able to find the Pelican article referred to above.
All advice appreciated.
Old 10-15-2018, 08:31 AM
I would rather be driving
jpnovak's Avatar
Here are some links with dimensions for the o-rings.
MFI Open Heart Surgery II - The Fuel Pump
rebuild MFI fuel pump O-rings
Old 10-15-2018, 08:53 AM
how about this one
Lorne M.
O-rings fuel pump 74-75
83 SC
Old 10-15-2018, 09:05 AM
Fuel Pump Refresh
Wow,
Thanks for the quick replies Jamie and Lorne. After carefully reviewing these, my pump is on its way to FIC.
Old 10-15-2018, 01:55 PM
911T Fuel pump
I just received my refurbished Bosch pump back from Fuel Injection Corporation. WOW!
I just wish that I had sent the first one there when it started to leak or the second one when I burned out the motor due to rust sediment in the tank.
Thanks FIC.
Old 10-27-2018, 09:35 AM
