High beam indicator weirdness
I need help from the electrical gurus on here.
On my 911 from 79, the blue high beam indicator is ON when I am on low beams, and OFF when I turn the high beams on.
Is my indicator stalk switch to be suspected?
Old 10-27-2018, 01:07 AM
ROW '78 911 Targa
timmy2's Avatar
Check the white/blue wire is on the correct fuse set (pair) at the front fuse panel. (Top white wire)
Maybe it got moved to the low beam set (pair) of fuses somehow?(top yellow wire)
It should be on the bottom of fuse 8 (with a blue wire) counting back from the headlight.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-27-2018, 01:33 AM
Just checked. It‘s on the right fuse. Would have been too easy.
Old 10-27-2018, 04:05 AM
I had similar problem a few years ago. Can’t remember the details but involved the high beams on when they shouldn’t be. I replaced the stalk and everything was fine again
Old 10-27-2018, 04:12 AM
Well I took the rev counter out, checked and cleaned all the connections and now it works. Beats me but hey who am I to complain ��
Old 10-27-2018, 07:33 AM
