ckelly's Avatar
Question Fabspeed fit problem?
Has anyone else experienced fit problems with a Fabspeed pre-muffler. I ordered one for my 80SC 3.0, from Joe at Fabspeed, received it, and attempted to install it, and low and behold....it doesn't fit
I ordered another one and explained my problem to him, even emailed pictures, he claims that's impossible as they're welded in a jig. I told him my stock cat fit fine, my Bursch by-pass pipe fit fine, but his does not, it angles off to the passenger side where the muffler attaches. I received the second one today, same thing
Anyone else have this problem, at nearly 300 bucks with shipping, it outta fit right? I'm sure he's sold hundreds of these, so maybe his jig has slipped or maybe nobody's complained. If there's enough response we can present it to him and maybe fix the problem.
Clay
'80 SC coupe
Old 03-08-2003, 06:59 AM
I recently ordered one and installed it about a month ago....fit perfectly. Can't imagine why yours isn't fitting. Joe's a pretty good guy...I'm sure he'll make it right.
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 03-08-2003, 07:02 AM
Somewhere in the Midwest
MotoSook's Avatar
I've heard the the Fabspeeds can be a bit off, but that looks like it was welded together on a ship at see in a storm. Can you loosen the muffler to try and mate the flanges?
Old 03-08-2003, 07:39 AM
Wavey's Avatar
Wow, that really is off, Clay. Is there any wiggle room in the rest of the system? I've read about this problem many times in this BB and at Rennlist. I'm working today but if I get time later I'll do a search on both. I also have a new one that I haven't had time to install yet, but just looking at it, it appears that the inlet flange isn't square to the outlet flange, just like your last picture. However, they way yours fits, it appears that the inlet flange is the culprit. I'm sure if we present Joe with enough evidence he'll make any needed adjustments to his jig.
As we discussed, you could probably get the inlet flange milled on an angle to get it aligned. The bolt holes may need to be cleaned up a little to get the bolts to fit, because then the holes would not longer be square to each.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 03-08-2003, 08:20 AM
Embs's Avatar
I have used their products in the past and I have to say they were excellent. Their customer service sucked, but their products fit my application perfectly and were very well made.
Old 03-08-2003, 08:35 AM
Steve W's Avatar
I notice what appears to be a big tip Dansk muffler there. What if you just shift the muffler over to the right a little?
Old 03-08-2003, 08:39 AM
ckelly's Avatar
I can't go to the right any more more, after taking this picture I loosened up the muffler again and moved it about another 1/2" over, still won't go, and the muffler tips are rubbing the rear valance, looks real lopsided too.
I can't tell if the inlet or outlet is the real culprit, after doing some measuring, looks like a little of both, I think if the inlet is milled the outlet will line up square. I clamped the inlet side down flat to my workbench, then measured the outlet height off the bench, as you can see in the pictures, here's my inch or so off.
How many people here have had problems??? I'd like to tell Joe this isn't an isolated incident and that I'm not incapable of installing this correctly.
Bursch by-pass
Stock kitty
Fabspeed pre-muff
Clay
'80 SC coupe
Old 03-08-2003, 09:15 AM
Not Quite Banned
Thomas Owen's Avatar
Mine fit perfectly. That picture with the framing square says it all - looks like the flanges just are not squared up like they shoud be. If that inlet is off by just a small amount it will kick the outlet over quite a bit.
(My Bursch bypass and original cat measure about 7/8" from the table up to the flange.)
Good luck,
Thomas Owen
1972 911T
1972 911S
Old 03-08-2003, 10:49 AM
SK SK is offline
SK's Avatar
I noticed that the flange on mine was a bit off square. Had some problems getting the flanges to snug up. It was not as far off as yours.
Old 03-08-2003, 08:39 PM
don911's Avatar
Mine was off as well. I loosend the muffler clamps and was able to get all the bolts started. I was able to pull everything up but wasn't happy with it. There's a lot of preload on everything.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 03-08-2003, 10:16 PM
ckelly's Avatar
Yeah, I could jerry it together I suppose then crank on it in order to get it close, porta-power maybe, but I don't think it would all hold, with that much load something would give at some point. Hopefully if I get enough feedback, Joe will at least take a look at the problem.
Clay
'80 SC coupe
Old 03-09-2003, 05:51 AM
After shifting my stock muffler 1/2-3/4" to the passenger it lined up fine.
Old 03-09-2003, 06:30 AM
Wavey's Avatar
Well, that's 3 that didn't fit - vs - 2 that did fit. Plus mine which is undetermined.
I clamped mine down like you did - pics attached. My inlet flange doesn't seem to be off as much as yours, as evidenced by the tape measure, but the outlet is definitely out of square like yours is.
It seems that we can at least say that quality control may be a problem. The welds and finish are top notch but his jig seems to be squirrely.
It will probably be a week or two before I get time to install mine (with a Dansk Sport muffler, single 84mm tip). I'll let you klnow how it goes.
Old 03-09-2003, 06:32 AM
SK SK is offline
SK's Avatar
I'm in the exact same boat as Don911. It did work with the stock muffler, but since then, I have built my own sprot muffler, so the flange offset became a non issue.
Old 03-09-2003, 08:14 AM
ckelly's Avatar
Does anyone else make a pre-muffler? Can you buy the OE euro version that I've seen a couple of times? Does anyone have part numbers or anything?
Clay
'80 SC coupe
Old 03-09-2003, 06:23 PM
mackpipes
Guest
Posts: n/a
One more for the not fit. Mine slants down to the rear, which leaves my Muffler hanging way too low. I've tried cranking it up there and tightening the straps but I'm weary of putting too much torque on the exchangers. My problem is the exchanger to pre-muffler flange. Love the sound but hate the look. I'll be giving them a call tomorrow.
Old 03-09-2003, 07:30 PM
ckelly's Avatar
Just an update....
Spoke to Joe at Fabspeed today, he is very concerned about the problem and is going to check his jig vs a stock cat as soon as he can. Needless to say, shipping and all my expeses were covered by him at his request.
Joe has seemed like a really good guy to deal with through the whole deal, I would recommend him for future purchases as he takes his products and their quality very seriously.
I'll post more when I have some more information.
Clay
'80 SC coupe
Old 03-11-2003, 12:22 PM
Wavey's Avatar
Thanks, CK. I'm going to take a day and try to get my system installed tomorrow. Let you know how it goes.
Old 03-11-2003, 12:47 PM
MotoSook's Avatar
Please post the results of Joe's findings.
Old 03-11-2003, 04:23 PM
Wavey's Avatar
Gave up and just installed the Dansk today, due to major hardware problems. Will try to install the Fabspeed over the weekend or early next week.
Old 03-12-2003, 01:44 PM
