89' Carrera 3.2 Randomly will not Turn Over
I have been having an issue where the car will not turn over. It does this randomly, but seems to happen more in warmer weather. This could be a sign but I don't drive it very often if its not 60 degrees. It is very hard to diagnosis because this only seems to happen when I have the vehicle and not a mechanic. I left it with my last mechanic for two weeks and he claimed he started it over 100x times successfully.
The day I drove it home, it wouldn't start again 10 minutes after i left the shop. Here is what has been replaced to unsuccessfully address the issue: Replace crankshaft and position sensor and bracket New plugs, cap, i.e. tune up New Starter Replace DME relay and Fuel pump The car did not have any issues for about a year (limited driving) with the replacement of the DME/fuel pump, but went back to doing the same thing this summer of not turning over. Any advice given I have spent around $2,500 to address this issue and multiple reputable shops have had a look at this? Any where in the west suburbs of Chicago you would recommend have a look at it? |
If it still has the orignal Bosch starter, they are prone to heat soak issues. They work great when cold, but heat em up and they lock up. If you have not tried the high torque starter available on Pelican, do that. Also replace the ground strap if it is old.
The other possibility is the plastic starter switch behind the key. If it always starts when cold, it is likely the starter. If the car will start up with a push start, it is likely the starter. |
Hi..if you are saying it will not turn over..is that it will not crank and it does not start??
Or it cranks but not fire up? ivan |
ok, it is turning over and it does not fire up....so..first do you have any alarm on your 911?
Second, who replaced the speed sensor? 3rd...Is it adjusted correctly? 4th..have you replaced the cylinder head temperature sensor? Ivan |
The Steve`s chip is no problem..Too bad your mechanic(if he is 911 specialist) did not start with the temp sensor.
That should be your next thing to do... Ivan Also if it is stock alarm..not the problem, most likely. |
Thanks Ivan - wouldn’t this really only affect the running of the vehicle, not the start up.
nope ...wise versa.....
Does it ever die on you while driving, even momentarily?
When you are cranking it and it is not firing up is the tach moving at all? It should be moving a little, almost vibrating. There is a way to test the CHT using a multimeter. I feel your pain, intermittent electrical/sensor problems are some of the most aggravating things out there. |
No, almost always happens after starting up then I park it, try to start it 10-15 min later and it doesn’t start. If I let it sit for an hour or two, it normally starts again.
here is a test you can do..But first have a look if you have the white connector with one or two prongs.If one it is the older version and a sign it has to be replaced anyway.
the sensor is about 80 bucks .. here http://img.pccreation.net/photos/201811042215587452.JPG |
I agree with the above statement.
Thoughts? |
My suggestion would be to disconnect it and try for yourself and/or at least do the test Ivan suggested (some time ago), come back with the results, and then ask for thoughts. |
| All times are GMT -8. The time now is 09:54 AM. |
