-   -   Need wiring connector: 3.6 distributor Hall Sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/1012234-need-wiring-connector-3-6-distributor-hall-sensor.html)
jpnovak 11-04-2018 06:55 PM
I am working on a 3.6 conversion. The engine wiring harness has a shielded wire that goes to the hall effect sensor on the distributor. This connector is broken and needs to be repaired.
Does anyone have a source for the 3-pin connector that goes to the distributor pickup?
It is not a normal Amp connector.
jpnovak 11-04-2018 07:08 PM
borrowing from a Renn List... picture.
I need this wiring harness connector.
http://forums.rennlist.com/upload/dist_copy1.jpg
donporfi 11-04-2018 07:18 PM
Can you post a picture of the broken connector ?
Is it a Tyco junior timer connector ?
Something like these?
http://forums.pelicanparts.com/uploa...1541391314.jpg
donporfi 11-04-2018 07:22 PM
If it is like the one on the right, Pelican sells it
https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&description=0 22+906+233+B
donporfi 11-04-2018 07:28 PM
If it is like the one on the left
https://es.aliexpress.com/store/product/DJ7033-3-5-21-good-sale-Tyco-3-pin-waterproof-connector-auto-and-motorcycle-wire-harness/3104041_32836091440.html?spm=a219c.12010108.100001 6.1.6aff482ahQqR03
HaroldMHedge 11-04-2018 07:42 PM
A Porsche 3-pole connector in that style is part number 022 906 233 B.
rsscotty 11-04-2018 08:09 PM
Finjector has great service and postage is cheap.
https://www.finjector.com/eng/3_pole_connector_set_for_ign_distributor_incl_term inals_and_b-p-518728-172
You can also call Motec East and talk to Larry. We have bought these from him in the past.
al lkosmal 11-04-2018 08:57 PM
Jamie,
contact timmy2 (Dennis Powell). He will be the one that can provide you with the answer.
regards,
al
PS: I've sent you his email address on the Pacwest Slack RG site.....
porschyard 11-05-2018 03:23 AM
hall sensor conn.
a couple of pics of the connector
+1 timmy 2
http://forums.pelicanparts.com/uploa...1541419971.jpg
http://forums.pelicanparts.com/uploa...1541420063.jpg
http://forums.pelicanparts.com/uploa...1541420268.jpghttp://forums.pelicanparts.com/uploa...1541420410.jpg
jpnovak 11-05-2018 03:49 AM
Thanks Everyone. Going down the path by following your leads...
Yes, the connector is the one with the extended Male section and 90 deg knife-edge connector orientation.
jpnovak 11-05-2018 08:22 AM
Just FYI.
The connector is Bosch PN 1234485024.
Cross reference is VW PN 052905327.
With the right Part number there are several sources available. About $15 for the connector, terminals and wire boot.
