I would rather be driving
jpnovak's Avatar
Need wiring connector: 3.6 distributor Hall Sensor
I am working on a 3.6 conversion. The engine wiring harness has a shielded wire that goes to the hall effect sensor on the distributor. This connector is broken and needs to be repaired.
Does anyone have a source for the 3-pin connector that goes to the distributor pickup?
It is not a normal Amp connector.
Old 11-04-2018, 07:55 PM
jpnovak's Avatar
borrowing from a Renn List... picture.
I need this wiring harness connector.
Old 11-04-2018, 08:08 PM
Can you post a picture of the broken connector ?
Is it a Tyco junior timer connector ?
Something like these?
Old 11-04-2018, 08:18 PM
If it is like the one on the right, Pelican sells it
https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&description=022+906+233+B
Old 11-04-2018, 08:22 PM
A Porsche 3-pole connector in that style is part number 022 906 233 B.
Old 11-04-2018, 08:42 PM
rsscotty's Avatar
Finjector has great service and postage is cheap.
https://www.finjector.com/eng/3_pole_connector_set_for_ign_distributor_incl_term inals_and_b-p-518728-172
You can also call Motec East and talk to Larry. We have bought these from him in the past.
Old 11-04-2018, 09:09 PM
al lkosmal's Avatar
Jamie,
contact timmy2 (Dennis Powell). He will be the one that can provide you with the answer.
regards,
al
PS: I've sent you his email address on the Pacwest Slack RG site.....
RGruppe #669
http://www.x-faktory.com/
Old 11-04-2018, 09:57 PM
lake wales fla
hall sensor conn.
a couple of pics of the connector
+1 timmy 2
Old 11-05-2018, 04:23 AM
jpnovak's Avatar
Thanks Everyone. Going down the path by following your leads...
Yes, the connector is the one with the extended Male section and 90 deg knife-edge connector orientation.
Old 11-05-2018, 04:49 AM
jpnovak's Avatar
Just FYI.
The connector is Bosch PN 1234485024.
Cross reference is VW PN 052905327.
With the right Part number there are several sources available. About $15 for the connector, terminals and wire boot.
Old 11-05-2018, 09:22 AM
