Camber 75 911
Rebuild the complete suspension front and rear. Lowered the car to the euro specs, now at 25 l/2 in front fender to ground and 25 rear. At this height I'm totally out of camber adjustment in the front. The various strut plates seem to provide very little adjustment and are very expensive, Any suggestions.
Old 01-03-2020, 06:41 AM
The solution is to bring it back up to true euro spec which is in mm, not in inches. The magic euro number for the front is 108mm etc. and your camber will be spot on.
Originally Posted by Bill Verburg View Post
Only US 78-81 SC were set at the factory at the raised height
here's a survey of the specs
height is the difference between a & b
Cheers,
Joe
Old 01-03-2020, 08:09 AM
put Thanks for the info Joe,
At the 25 1/2 fender measure which converted to the proper measuring method is 141mm. To reach the euro would raise the car a good 2 inches at least. Years ago it was at the factory setting, our cats used to sit on the tire and look at us without bumping their head.
We had the car lowered many years ago and the rake was awful and the front had the camber maxed out.
So after rebuilding the suspension we're trying to lower the car to a reasonable level which seems to be in the suggested 25 1/2 or so area. At this level the camber seems to be around pos 1 degree. Suggestions I've seen are around .5 neg. AT my present level I will have to start going up to achieve the .5 unless someone has any ideas.
Thanks for the input
Last edited by jimgreenery; 01-03-2020 at 09:37 AM.. Reason: used neg instead of pos in relation to degree
Old 01-03-2020, 08:53 AM
Static camber should become more negative as you lower the car though.
Matt - 84 Carrera
Old 01-03-2020, 12:26 PM
Under the radar
Trackrash's Avatar
Agree. Are you sure about the pos 1 deg? As the car is lowered, up to a point, the camber gets more negative. Most struggle with negative camber in a lowered car.
How are you measuring your camber?
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-03-2020, 12:38 PM
Location: behind the redwood curtain, (humboldt county) california
Tires to short???
What size tires are you running?? What is the overall diameter?? With a short tire, you would have to raise the car to get that 25.5 inches, which would likely give you postive camber.
Im running a short tire but will lower the car below Euro Fender height to get the suspension geometry right, then corner weight and align, if I am not dragging on the ground.
I know Bill has posted a lot of charts with wheel and tire dimensions. Throw a tape on your tire and see how it compares to a "stock" size tire, (IIRC, that is about 25 or 25.5 inches), not to be confused with "fender" height.
goodluck,
chris
Old 01-03-2020, 01:35 PM
I'm running 195/65x15. Today raise the car to 25 7/8 ended up with 1 degree neg. with no more adjustment. I think I'll leave it here and see what happens, we had raise it up more but did not like the look. At this point the rear has about a 1/2 inch rake. I do not want to remove the rear torsion bars and reset. I can live with the look and if the drive with the 1 degree is ok I'm good to go. Thanks for the responses.
Old 01-03-2020, 04:42 PM
