David 23's Avatar
Plug heater tube holes in engine tin
I have removed the heat from my '79 SC backdate hot rod, and need to plug the two now open holes (60mm and 65mm) in the engine tin. There must be some type of snap in plastic, metal or rubber plug that will go into these sheet metal holes. Any ideas?
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 11-06-2018, 10:53 AM
Runnin on empty
acme911's Avatar
I used ABS pipe caps and turned them on my lathe for a convex surface then used black silicone to adhere them.
A Werk in Progress
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 11-06-2018, 12:38 PM
ROW '78 911 Targa
timmy2's Avatar
Electrical box hole metal filler plugs at your local hardware store. Various sizes available.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-06-2018, 01:12 PM
