Midwest R Gruppe
t6dpilot's Avatar
Door Card Material??
Looking to make some simple RS Lightweight door cards. I have black vinyl in the car and want to change the color. Appbiz has this:
RS/RSR Door Panel Do it Yourself Kit
But it is just a template. Wow, shocked that you pay $300 for a template of the door card and not the card itself. Anybody done this have a recommendation on door card material? Appreciate you pointing me in the right direction.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 11-04-2018, 02:13 PM
Harpo's Avatar
I believe it is just melamine and available @ Lowes & HD
Old 11-04-2018, 02:42 PM
Recently Disbanded
juanbenae's Avatar
I could be referencing the same thing harpo has in "melamine", but 1/8" high density particle board will work. it can smell for a while so priming it with kiltz or other like wood primer also solves any concerns in regards to moisture.
have you considered simply tracing the old ones? I understand Appbiz's reluctance to undersell themselves by providing a cheap template when they'd prefer to sell you their finished project.
frankly, the Appbiz packages can't be beat with handles, fasteners and often a life time of customer service. bob often provides bits for his products long after the sale which are not off the shelf stuff complimentary, free of charge with in reason..
Old 11-04-2018, 03:22 PM
300hp 1800lbs is the goal
pksystems's Avatar
Carbon fiber and some epoxy on a piece of waxed glass.
Old 11-04-2018, 05:03 PM
Recently Disbanded
juanbenae's Avatar
Old 11-04-2018, 06:36 PM
I used Coroplast when I made mine. I took two thin sheets and laminated them together with the corrugations angled 90° apart. They have held up very well and are impervious to water. Super light as well.
Old 11-04-2018, 07:02 PM
Administrator
Jack Olsen's Avatar
I also used corrugated plastic. I think it's the perfect material for this. I used a 3/16" piece, and adhered leather directly to it. No more worries about heat or water messing things up. And it's much lighter. I also (because of car anorexia), replaced the upper trim piece with aluminum sheet, covered with leather.
Old 11-04-2018, 07:51 PM
Formerly known as Syzygy
Canada Kev's Avatar
Nice mini winder, Jack - doesn't foul the dash and it fits in with your weight loss program without resorting to bulimia...
Kevin
Old 11-04-2018, 07:58 PM
Administrator
Jack Olsen's Avatar
The shortened winder and the notch on the forward edge of the upper trim piece are all to clear the cage. But it's true; they also cut weight.
Old 11-04-2018, 08:00 PM
Cory M's Avatar
1/8" luan hardwood works too and you can get it at Home Depot, it's what was recommended in the custom interior books I read several years ago, used it on my hot rod and it was easy to work with
Old 11-04-2018, 10:42 PM
scumbag
Jack,
do your doors lock only with a key? or not at all?
Thanks!
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 11-05-2018, 05:44 AM
Midwest R Gruppe
t6dpilot's Avatar
Coroplast - perfect! Thanks guys. I hadn't thought of looking for that at HD. I just assumed all they would have was plywood products.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 11-05-2018, 05:53 AM
Administrator
Jack Olsen's Avatar
If you have a plastic supply store in your area, you’ll have a lot more choices with regard to thickness, and the prices will be better. A sign supply shop will also carry the stuff
Old 11-05-2018, 07:19 AM
I've used 1/4" tempered masonite (from Lowes). It's think enough that you can use door attachment plastic gizmo's to plug into the factory holes. Use your old door card for a template and it's really very easy to install and cover with vinyl/leather using spray adhesive and a little contact adhesive at the edges to not need to use an upholstery staple at all
Old 11-05-2018, 08:53 AM
Midwest R Gruppe
t6dpilot's Avatar
No plastic supply store that I can find, Jack. However, we do have a couple of sign shops. I'll check them out. I like your idea of fabricating an aluminum upper trim piece. Mine are the bare metal of the stock door top with the padding removed. Has a vertical lip that digs into my arm constantly. I installed a stock padded one and while I like the look and comfort over my bare metal one, I do not want to screw into it to install the leather strap stay. Your aluminum solution should work great.
I have simple plain black panels with leather latch release and plastic door pull. My 69 lightweight hotrod has the window winder mechanism removed and pull up lexan windows installed. Was planning on using those as patterns. Photo is from 2006 when I bought the car.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 11-05-2018, 12:33 PM
Administrator
Jack Olsen's Avatar
I remember trying the aluminum idea as a lark. I had some sheet on hand and I used a 2x4 as a shape to bend it over. I had to do some more complicated bending for the cutaway part to accommodate the bar for the cage, but at the time my thinking was just 'I'll try this and see how close I can come,' and I ended up using it and being pretty happy with it.
This is the only picture I can find that shows the aluminum -- turned over on its back, here. But you can see the basic idea. I think I sort of sandwich clamped the aluminum between a 2x4 and a smaller piece of wood and then slowly folded it over. Then you can trim it to the right dimension and move on to the other side.
Old 11-05-2018, 12:53 PM
The "template" comes with some parts....to quote: "the wimpy plastic handels" [no sure what handels are]
...........and "Long embossed leather opener strap, Handle anchor kit with setting tool (we anchor our handle to the door, not the door panel like others), (6) plastic panel panel retainers, screws and trim rings and complete instructions.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 11-05-2018, 04:14 PM
Cars and Cappuccino
tdw28210's Avatar
Using aluminum for my door cards on my project car.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 11-05-2018, 05:41 PM
I'm good with tools.
AG81's Avatar
I used 1/8" thick birch and made my own pattern from the existing door card. I also thought the cost of the pattern was too expensive.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 11-06-2018, 04:30 AM
AG81. Cool handles! Are they VW or 356?
Old 11-06-2018, 08:19 AM
