I need to know what form of measure or how do I decide whether my rotors need replacement or not. Track season is hopefully just about upon in the northeast, and I want to be prepared. Can someone please advise me...
The Bentley manual for 911SCs states that rotors should be replaced when the fronts get down to 18.6 mm and the rears get down to 18 mm. You didn't say what kind of car you had, but if you have an SC, those are the measurements.
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
First it depends on the year of your car. I can't tell the year from your post. You need a micrometer to measure the thickness. When a minimum level of thickness is reached, they should be replaced. Of course if they are warped or cracked, they should be replaced.
The fronts on my 79 are easy to access. The rears have a dust cover on the inside that requires you take the measurement right at the brake caliper unless you want to remove the covers. If you decide to remove the cover, there are two bolts holding them in place. A chart on the Pelican site shows minimum thicknesses for rotors. Click on 'rotors' in the attached link. This chart is for 1974 through 1989 911's. http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_brakes_main.htm I'm taking a break from working on my rear brakes at this moment. Anyway, here's a shot of where you would place the micrometer on the rears to measure rotor thickness. Last edited by autobonrun; 03-09-2003 at 04:43 PM.. |
Thank you so much!!! I have an 88 911 BTW.
Error in my post.
Got it. I didn't realize they have so much on the site...Thanks again.
Author of "101 Projects"
Tons on this site. Use a micrometer to measure the discs - not a dial caliper. The edges of the discs are thicker than the middle where the pads wear...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne!!!
