CO test meter
Many folks here say to check the CO to make sure the motor is adjusted correctly. My question is where can I find a cheap gas analyzer ? My local Porsche tech says he checks it by feel. If I go to one of our local fancy San Diego shops they will charge $300 for a 5 minute job with their equipment. I would like to buy the equipment.
Old 12-08-2018, 10:55 AM
walt's Avatar
A digital wide band sensor like this would do it. https://www.innovatemotorsports.com/products/mtxl_plus.php
You can also research the push/pull method on the air sensor plate. It's a good way to rough it in and won't cost you a dime.
Walt
82SC 3.0
81SC 3.6
Old 12-08-2018, 01:34 PM
That Guy
Techno Duck's Avatar
Any wideband will work. I had one of the original Innovate widebands in my 951 and have a AEM in my 911.
You will need another O2 sensor bung installed. You can also run it with a tailpipe clamp but its not as accurate.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-08-2018, 01:59 PM
I have an additional O2 sensor in my cat bypass connected to my my AEM wideband air fuel gauge installed below the ash tray in my 1982 sc. This gauge is one of the most useful things I have done. It takes the guess work out of tuning and allows me to see fuel ratios from cold start up through wide open throttle.
Dave
Old 12-08-2018, 02:58 PM
You might be better off learning to check it by feel like the pros do since a cheap analyzer would be useless without proper training on how and where to place the probe.
Cheers,
Joe
Old 12-08-2018, 06:31 PM
Under the radar
Trackrash's Avatar
The AEM is the way to go. Around $200. The only thing is you will have to install the O2 sensor in your exhaust system.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-08-2018, 06:39 PM
you can convert CO directly to AFR.
Wide band AFR is the way to go.
AIM is popular but not great. I prefer the Daytona-Sensors WEGO IV. Great instrument.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 12-08-2018, 10:31 PM
evan9eleven's Avatar
+1 on the AEM meter. Mine replaced an Innovate meter. The AEM has a gentler heating cycle for the O2 sensor then the Innovate, which has a reputation for killing sensors. My first one died after just 300 miles of tuning, replaced with AEM and all is well. Affordable too.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 12-09-2018, 02:05 PM
Are the readings really that much different before the cat and at the tailpipe? My Porsche mechanic seems to not think so. He told me the best way to check it is with a California smog tester . What do you think ?
Old 12-09-2018, 09:04 PM
-1 with the Innovate unit. I purchased one several years ago and hasn't been utilized once. Waay to complicated, I have resorted to pulling the spark plugs. I like the idea of knowing your A/F ratio, maybe an AEM unit is in my future.
Old 12-10-2018, 03:58 AM
Under the radar
Trackrash's Avatar
If your cat is working there will be a difference. Just ask all those Carrera owners that had to replace their cat to pass smog.
If you are trying to tune your motor, measure before the cat.
Gordon
Old 12-10-2018, 08:41 AM
Find an old used LM1 with tail pipe sniffer. Accurate and inexpensive. Heck, even my old Heathkit is 100% accurate to my LM1 and it converts AFR to CO right on the scale. The Heathkit was $25 on CL.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 12-10-2018, 11:18 AM
good investment, I checked, they are not $25 anymore
crude rudy
'84 cab
'14 ZX-14R
Old 12-10-2018, 07:43 PM
