Alternator rear bearing cap replacement
Long story short I found out that the rear bearing cap on my alternator is toast. (pic attached). Doesn't seem plausible to glue it together so where can I find a new one short of buying an entire alternator? Don't think it has a separate part number.
Old 11-25-2018, 09:44 PM
Don't know where to find an original one but I think an engine freeze plug would be a good substitute.
Old 11-26-2018, 08:00 AM
76 911S Targa
Had a similar problem a few years ago. I believe that plastic cover also centers the bearing in the alternator housing. When it failed, the bearing failed and the alternator seized. Actually, I suspect the bearing, as it fails, heats the plastic which then melts. You can buy a new bearing from any of several online suppliers of alternator rebuild parts. I had the failure occur on a trip away from home, bought the replacement Valeo alternator from Pelican and installed it in the motel parking lot. My old French alternator is still awaiting a rebuild.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 11-26-2018, 08:09 AM
Caps are available from alternator rebuild supply houses try searching "paris rhone bearing cap"
Old 11-26-2018, 10:02 AM
Been looking around. Nobody seems to have any.
Old 11-26-2018, 06:25 PM
76 911S Targa
My advice at this point is to do a complete alternator rebuild. I took mine to a shop and they said they could get all the parts and have it rebuilt in 3 days. A quick search found this:
https://store.alternatorparts.com/import-vehicle-alternator-parts.aspx or this:
https://www.aspwholesale.com/index.php
There is a nice forum post on rebuilding your own alternator which maybe someone else can find for you. I haven't found it yet.
Old 11-27-2018, 09:25 AM
These people were very helpful when I needed parts to resurrect a couple of junk Marchal alternators. They stock rebuild parts for many brands of alternators and starters. Perhaps they can help with your Paris-Rhone.
They're in the UK, but shipping to me in the US was fast and cheap.
Edit: you didn't ask about the bearing, but IMO it's worth replacing it since you'll be in there anyway. Getting a new one is just a matter of getting the number off of it and going to your local bearing shop; it'll probably leave you change from a five-spot.
Old 11-27-2018, 02:02 PM
