PeteBrown's Avatar
EPS fan shroud doesn't fit - tips?
My EPS fan shroud does not fit into my '87 and I opened up the bottom grove for the key and have been filing the outside diameter to try to make it fit. I've searched and searched and other experiences vary from it installed the first time, to it "took 30 hours" of modification to get it to fit.
Does anyone have any tips on how much and where to take material off the shroud? Any advice would be greatly appreciated.
Thanks,
Pete
Pete Brown
'87 911 Coupe
'20 718 GT4
'25 Aviator
'25 Mach E
Old 10-16-2016, 05:40 AM
Photo's of the shroud and the area of your problem would help. What kind of material is it made of?
Old 10-16-2016, 07:20 AM
I took mine to machine shop. They shave 3/16" off the top half (0-180 degrees)
Then I went over to body shop. They cleaned and painted EPS to match body color.
Worth the effort in the end.
Old 10-16-2016, 08:32 AM
PeteBrown's Avatar
Here are the two shrouds from the bottom:
Shrouds top:
Shroud not in at the top:
Shroud not in at the bottom:
Pete Brown
'87 911 Coupe
'20 718 GT4
'25 Aviator
'25 Mach E
Old 10-16-2016, 09:38 AM
PeteBrown's Avatar
ma356r:
How did you determine to take material only from the top? I assume that was from 9 to 3 o'clock? I ask because some (duc hunter) said the shroud sits too high causing the air vanes to be trimmed? Would it make sense tot take 1/8" off the top and bottom from clock speak 10-2 and 8-4?
Thanks,
Pete
Pete Brown
'87 911 Coupe
'20 718 GT4
'25 Aviator
'25 Mach E
Old 10-16-2016, 09:42 AM
On mine, the bottom fit. It was very tight, but fit.
Same issue you have on top. So I machined only top 9-3 where engine shroud fits and bolt holes align. Additionally I opened 1 of the engine shroud bolt holes.
You'll get there.
Old 10-16-2016, 09:53 AM
Discseven's Avatar
Pete... that appears to be major misfit. Am wondering if you had discussion with EPS concerning situation? (If diameter is too great, it can easily be mounted on a lathe for trimming. Did this with Vertex housing for purposes of cutting out alt seat for a better fit. Bolt holes can then be tapped deeper if needed---assuming enough material.)
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 10-16-2016, 11:38 AM
db_cooper's Avatar
Looks like there is a German made reproduction part available, made out of magnesium for about $440 plus shipping. Could be a an alternative to the USA made EPS fan shroud. Who knows if it fits better..it should.
Porsche 911 fan housing alternator 1978 - 1989 3,2 Carrera 3,3 Turbo - CarPoint
Old 10-16-2016, 11:56 AM
Ken911's Avatar
Yeah the pictures look like a much better quality casting.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 10-16-2016, 12:20 PM
That's a fan housing not a shroud. The shroud covers the housing.
Old 10-16-2016, 11:31 PM
PeteBrown's Avatar
installed
I was able to get it the fan housing in yesterday after shaving 1mm or so off the outside diameter. As Duc Hunter reported, it sits a little high and as a result the air vanes interfere with the back of the large engine shroud. Going to try to reduce the fan housing height before modifying the air vanes.
Pete Brown
'87 911 Coupe
'20 718 GT4
'25 Aviator
'25 Mach E
Old 10-17-2016, 06:06 AM
Just found this thread. Glad to have been of some help. Mine is still in and ok. I am considering the CarPoint Magnesium fan housing. Not many people seem to have tried it, so no reports on the fit or not. If I get it and it works I will post accordingly.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-29-2017, 06:40 PM
After the next project
x98boardwell's Avatar
Did anyone ever get the CarPoint Magnesium fan? If so, how did it fit? Thanks
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel
Old 02-16-2020, 06:11 PM
