Reiver
Reiver's Avatar
Valve adjust with Kirk tool
Thought it looked pretty well thought out so got one from our host and usedit today.
1983 SC euro...CIS
Once you get a feel for the tool it really works well...never brought out a feeler gauge and did all 12 in a pretty quick series...once around the horn and no checking.
The tune up is very nice and this does give you a nice setting....just a hint of valve train noise...no loud ticking. The warmed up run was excellent with great response....very nice tool.
I also used info posted here too....dry gaskets...first tighten to 10 ft. lbs sequentially and then a final to 18 ft. lbs. Dry as a bone.
I recommend the tool as user friendly.
De Oppresso Liber
Strength and Honor 5th Legion
Old 12-04-2018, 06:11 PM
Just got one. have not used yet, looking forward
Thanks for input
82 SC Twin Plug 3.2 SS ,46 PMO
Old 12-04-2018, 06:27 PM
I bought one, didn't really feel comfortable with it.. sold it on.. next fellow loves it.
Guess it was just me.
Old 12-04-2018, 06:37 PM
Have one. Used it twice. Prefer the feeler gauge.
Keep the kirk tool super clean after use so as not to skew the reading. Ask me how I know
Old 12-04-2018, 11:31 PM
Valve cover torque for the nuts seems a bit high? I thought it was only 6 ft.bls from memory.
Old 12-05-2018, 02:15 AM
Reiver
Reiver's Avatar
It is....but those are studs with 13 mm lock nuts and if you do a search you'll find a respected builder here who recommends that...dry gaskets and sequential torque to 18 ft lbs....on the engines he builds and services never a valve cover leak and no issues with the covers either.
De Oppresso Liber
Old 12-05-2018, 07:54 AM
SCadaddle's Avatar
Hrrrrrummmmphhh......he done told me 15 ft. lbs.
Old 12-05-2018, 10:38 AM
Reiver
Reiver's Avatar
Dif guy...never asked Yoda…. dry as a bone...had a slight leak on the number 3 rocker shaft for awhile....can't get a torque wrench in there so just used quick weld lightly around the outside...its on the dry side anyway so what the heck....worked too.
De Oppresso Liber
Old 12-05-2018, 11:48 AM
Reiver,
Quick question, which gaskets did you buy?
I am going to do this soon, just wondering as there seem to be a lot of options.
Thanks,
Craig
77 Ice Green 911s w/3.0
Old 12-05-2018, 11:54 AM
I don't like the Kirk......prefer the 36 degree screw drive type adjuster.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 12-05-2018, 12:32 PM
Reiver
Reiver's Avatar
Originally Posted by Craig View Post
Reiver,
Thanks,
Craig
I bought the Porsche kit from our host....they have the Reinz gaskets...just cleaned the surfaces well on the lump and the covers. Snugged them, then sequential torque to 10 lbs, center out and finally to 18 sequentially.
Just drove 50 miles and not a drop.
De Oppresso Liber
Old 12-05-2018, 12:43 PM
Thanks Reiver
Craig
Old 12-05-2018, 12:47 PM
shbop's Avatar
The size of the nut, or stud, doesn't matter. Bending the cover, so it's no longer flat, does. I dress mine on a thick piece of glass with 220 grit wet and WD 40. You'd be amazed at what you'll find the fist time.
Jon
Old 12-06-2018, 06:42 AM
Reiver
Reiver's Avatar
The size of the stud always matters...or so I've been told.
Yes, have done that and still had leaks at the 6lb. T....I don't worry about that issue anymore just torque to 15-18 lbs. and go.....dry as a bone. Two builders I know, one that rebuilt the top end on my 930-10, do this and the latter has been a certified P mech and shop owner for over 40 years.
De Oppresso Liber
Old 12-06-2018, 07:25 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
You know what they say about folks who claim that size doesn't matter!!!
Old 12-06-2018, 08:28 AM
Can you expand a little on what you refer to as the 36 degree screw type actually is? is there a specific brand/tool you are using?
Old 12-06-2018, 10:06 AM
Vintage Owner
Jack Stands's Avatar
The screw type adjuster uses the thread pitch as a determinant of the clearance. You simply tighten until the follower contacts the valve, then back off the 36 degrees to get the appropriate clearance.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 12-06-2018, 10:22 AM
This is a pic of the 36 degree screwdriver tool.(pic from fellow Pelican "Rusnak").
The 36 degrees is the angle between the pointers. It uses the same theory
as the Kirk tool, in fact, the Kirk tool is probably based on this tool idea,
except in a much more elegant design.
Basically you remove all valve lash with the screwdriver, then back off
the screw driver to align the pointer to the previous pointer position.
Easy peasy, but I think the Kirk tool is much more precise. Just my $.02
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 12-06-2018, 11:50 AM
