Heck, I知 only 5 not 71!
Cruise Control vacuum line issue on 1980SC Targa
I have started working on the cars ancillary systems that have stopped working over the years and naturally create a challenge to get them working again.
The first three are now working.
First some history, cruise control worked with a very slow drop in speed over time while driving. (research shows that this may be an issue with capacitor C19 deteriorating with age). In the late 90's I did an engine rebuild and after installing the motor the cruise no longer worked (Fast forward to now, (I Know, what took so long, Poop happens, but now I'm retired with free time on my hands). After doing all of the multi-meter tests I found the clutch switch needed adjusting. The cruise will engage with switch Set activation and car will accelerate but will not hold speed once Set switch is released. Before I start troubleshooting the tempostat control unit, I need to verify the vacuum connections between item 15 tempostat Servo Motor and the tee connector between item 13 Deceleration valve and item 1 throttle housing as noted in the Vacuum Line Layout for the 1980 911SC model below. ![]() The Porsche repair manual diagram shows item 15 Vacuum Limiter (Deceleration Valve) connected directly to item 4 Flap Nozzle (Throttle housing) ![]() This is a picture of my motor after my rebuild and it clearly shows that the vacuum line on the Deceleration Valve is connected directly to the Auxiliary Air Valve. I did connect the Tempostat Servo Motor vacuum line directly to the open vacuum connector on the throttle housing after the engine was installed. The open connector is in the middle of the picture next to the frequency valve. Can anyone provide a picture of the engine vacuum line setup between the two valves for a 1980 model or provide info on how theirs is setup. The only thing I can think of with my setup was that I got it wrong when I put all the ancillaries back on the engine. As a side note the engine CIS system runs as advertised with no issues. If I am right in my setup then the pubs are not accurate. Your thoughts and insight would be appreciated.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
I have a 1980 SC Targa, just dropped my engine, I don't know what the two valves are, I have a lot of pictures of the engine out of the car, can you give me better detail and I can get you some pictures of that area
-also can you post some pictures of your car, mine is Mocha Brown also but was repainted, I'm changing it back to Mocha Brown
1975 914 1.8l 1979 911SC Targa - In Restoration 1972 Pantera Dune Buggy Dual Port 1835cc 1980 911SC Targa - Driver/Winter Project |
The first picture in my post shows the two little flying saucers (Brass Discs with hoses attached. I believe the lower one is the Deceleration Air Valve and the top one is the Auxiliary Air Valve. There is a small vacuum line connecting the two together on the oposite sides of the larger hose connections.
The two air valves are indicated by the arrows I believe the upper is Auxiliary Air Valve and the bottom one is Deceleration Air Valve. As you can see the two small vacuum lines are connected together is this correct for an 1980SC 3.0L engine with cruise control?
I'm Starting to think that someone prior to me owning the car replaced the the Auxiliary air valve with a Deceleration valve. Any search I have done shows the Auxiliary Air Valve without the small vacuum nipple.
You are having a problem with the electronic control module. I have worked on many cruise modules and that is a very common fault. My advise is to send your module to the guy mentioned in this thread. Don't bother with trying to replace capacitors or other components and stuff. Several folks have had great results from this guy and at his price, it's not worth messing with the module yourself. New Cruise control repair guy on the block ![]()
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Uwanna, Thank you for the advice and at some point I may move in that direction but for now I would like to resolve the issue that I have with how the vacuum lines are connected to the Decel and Aux air valves on 3.0L motor. In my own situation things are just not adding up with the configuration I presently have even though the engine runs great. Once I get the vacuum lines issue straightened out then I will tackle the tempostat control unit. I do not shy away from troubleshooting component failures on electronic modules, in fact I derive a little bit of satisfaction from repairing faulty equipment that I own.
picture of my 1980
so far from everything I see I think my car is pretty original and not tweaked much, this is a picture I had saved, can get you any picture you need tomorrow, don't forget to post pictures of yours, I want to see Mocha Brown
ok found this one too, you can see where the vacuum line on lower vacuum pot runs to
my pictures show only one of the pots with a vacuum nipple on it
[QUOTE=smarens;10299593]ok found this one too, you can see where the vacuum line on lower vacuum pot runs to
Looking at your last picture the vacuum line from the decel air valve runs directly to the throttle housing with no tee in between for cruise control. Question is do you have cruise control in your car? If you do where did the vacuum line from tempo stat servo connect to?
-do you want pictures of my cruise servo or anything else?
Finally found another picture of a 80SC with both the Decel and Auxiliary Air Valves having a vacuum line port. In the picture the upper unit (Auxiliary Air Valve) has no connection. The bottom unit (Decel Air Valve) has a vacuum line attached with a tee connector branching off to the throttle housing and the open end would be for the Tempostat Servo Motor.
Still here
The engine pics above do not show the CC connection ... it wasn't a standard feature on these cars (I think). That hose from the TB goes to both the DV and CC actuator. Many have the DV plugged so that's another mod to be aware of.
After doing another internet search it seems there is an older version Decel Valve.
![]() ![]() There is also a different set up with the newer Decel Air Valve and the normal Auxiliary air valve without the small vacuum line port. ![]() In essence having the two small ports connected together on the Decel and Auxiliary Air valves in my configuration eliminates the Decel valve from operating normally by not supplying a vacuum to it. The throttle body vacuum port was connected directly to the Tempostat Servo Motor so there was no open vacuum port. Now that I have that figured out its time to look at the Tempostat Control Unit.
keep us posted, I want my cruise (and everything else) on my car some day to all work
Pat I have an '82 and that's how my lines are connected also.
That top flying saucer is definitely wrong. That looks like another decel valve to me. It should be an AAV that looks like: this ![]() ![]() It gives an extra puff of air on start and closes on vacuum. Check for holes in the metal pipes. The airbox rubber mounts sag and the pipes rub on the engine shroud. |
