Thanks. |
I was always prying out the spring clips and I ended up chewing up and breaking a couple of the plugs. They actually just pull straight off without removing then spring clip. If you use a little thin screwdriver and just very lightly insert the blade and twist under the plug it just pops right off. If I had of known this when I was disassembling my CIS it would have probably saved me a couple of hours sheesh.
Easy to lose. Too much tension and it will fly and disappear. 15 years ago you could go the the bone yard and snag all the clips and connectors you needed off of 1980's VW's. They are thinning out. |
WyattEarp:
All very interesting discussion, but back to you. Your original post said it was hard to start but once running, seemed ok. That, to me, clearly indicates a problem with the cold start system (Thermotime switch or CSV). Have you been able to verify all is connected properly? Have you been able to verify all is working? Inquiring minds want to know. |
I guess it was the tangential discussion on how to remove a clip. Interesting, somewhat on topic, but the "not the main event". |
By no means the main event but pertinent, however small. Functioning CSV will start the car every time. OP ain't got that going on. |
It is pull/push plug.........
Pmax, You don’t need to pry and remove the spring to unlock or remove the WUR plug. How often do you work with this push/pull type square electrical plug lately? The WUR’s used in CIS have this type of plug on them. The spring is used to secure and lock plug in place. The plug will not come off easily without applying sufficient side to side pulling motion (wiggle) to unlock this spring. Look very closely on the locking tabs on the sides of the plug. For installation, outer angle of the tabs is approximately 45° and the inner tabs have greater than 45° slope. So you would need a much greater effort to remove or pull out the plug compared to installation. If is mandatory to use a pick for removal, how on earth would you be able to remove the AFS switch plug, CSV plug, or FV plug with the engine in situ? I will give you several hours to remove this spring with engine in situ. The key to removing this type of plug is to exert a side to side pull (wiggling) to get the locking spring slide over the the locking tabs. Go over the garage and practice removing it. I’ve been working with Bosch WUR’s for many years now and I could not recall exactly how many times I’ve done this maybe several hundreds or thousand times (?). People been doing a lot of reading and that is good. But they lack hands on experience. This a very good example how people think and understand how CIS works. And this is just the “spring”. Wait till it comes to actually doing the CSV and fuel injectors tests and evaluation. Tony |
Test and confirm.......
Bob, If you have not checked or tested the CSV, how would you know it is good or bad? You can not evaluate the CSV nor the fuel injectors without dismounting them from the engine. What the OP needs now is to know and understand how to remove and test the CSV and injectors to evaluate them. I intentionally avoided earlier getting involve in this post to allow others to participate and offer his/her advices. The more people participate in a given thread the better. A good working CSV does not guarantee you that you could start and run the car. A CSV is a very robust and dependable CIS component and it hardly fails at all. But the key is how to test and evaluate CSV if you are able to dismount it from the engine. The removal is easy but cumbersome or tedious with the car installed. BTW, have you completed the restoration of your SC after the accident? Happy Holidays my friend. Tony |
However, I assumed that was the way to do it. It worked, but a pain in the ass. I was wrong. OK, it can be literally pulled off. Which is awesome. What does that have to do with not being able to understand other CIS testing methodology? One of the easiest things I did on my top end rebuild in the 90's was cam timing from a genuine work perspective. It was easy. Girl work. Set up indicator. Overlap TDC. Shift the pins as needed Snoozer stuff. The subject is a simple mechanical discussion about how to remove a connector. NOT a dissertation on mental capability wrt CIS. |
I have one car pal left as two died in the last year. The remaining is a sheet metal wizard. Thankfully. How selfish is that? I bought all the exterior parts from a car in Canada. Hood, fenders, bumpers, etc. $2,500 which was probably a bargain. The front tub is the rub. Tree hit drivers headlight spot on and supports moved things around. I can expound upon this but not the place. Suspect $2,500 in straightening then the $2,500 of parts can be hung. |
No running was referenced. |
poor silly pnut! your team is turning on you!! :confused: |
Just focus of these........
Wyatt, Ignore the other distractions. Simply focus your effort on what Harry is asking you. If you have any problem, simply ask. Keep us posted. Tony |
Will practise that wiggling technique on my spare harness connector. Back to the OP's issue ... |
| All times are GMT -8. The time now is 07:57 PM. |
