-   -   CIS Cold Start Problem Did Pressure Tests Now What? (http://forums.pelicanparts.com/porsche-911-technical-forum/1015097-cis-cold-start-problem-did-pressure-tests-now-what.html)
Bphawk1 12-09-2018 08:07 AM
Have you checked fuel pressure at start and ever replace the fuel filter? I had that problem with my 83 SC.
WyattEarp 12-09-2018 08:08 AM
I haven’t gotten the chance to get back to continued trouble shooting yet. Hope to have some time to spend with it tomorrow. Will report back my findings
gazzerr 12-09-2018 06:16 PM
You don't even have to wiggle if you use the screw driver method I talked about. Just be gentle. Try it on your test connector. It takes a millisecond ... anyway ... like you said back to the OP's original question.
I actually removed them all in situ prying out the spring clip and as Bob said I'm glad the large caliber weapon was not available. I learned the hard way when it comes to these plugs.
boyt911sc 12-09-2018 06:38 PM
Plug removal.......
Originally Posted by gazzerr (Post 10278697)
You don't even to wiggle if you use the screw driver method I talked about. Try it on your test connector. It takes a millisecond ... anyway ... like you said back to the OP's original question.
Gary,
Since you could remove this plug in milliseconds, I will give you an opportunity to demonstrate your technique. Try to remove the plugs for the AFS, FV, and CSV with the engine installed using your special tool. And I will give you 10 mins. to remove them. You could not even see these plugs with the engine in place. How could you even pry these tiny springs off?
These plugs were built and designed as push/pull plugs as a quick disconnect connectors. Keep us entertain. Thanks.
Tony
WyattEarp 12-09-2018 06:53 PM
Was able to do some testing of my thermotime switch tonight hopefully my explanation below is clear enough. I removed the switch from the car and tested on a bench.
Large terminal on switch = red black wire on car (this grounds the CSV)
Small terminal on switch = yellow wire on car (power at cranking)
I grounded body of switch and connected my test light between large terminal of switch and + and my Test light comes on.
With the above still connected if I apply power to the small terminal of switch my test light goes out immediately.
So this seems to indicate the switch is bad. Shouldn’t my test light stay lit for approximately 3-5 seconds when I apply power to the small terminal? If I’m understanding this circuit correctly with the CSV then when my car is cranking at startup my CSV would not have a ground and thus not be giving my car the extra shot of fuel at cold start right?
juanbenae 12-09-2018 07:01 PM
Originally Posted by boyt911sc (Post 10278722)
Gary,
Tony
who's the boss? tony is.
pmax 12-09-2018 07:34 PM
Gary,
Tony
OK to settle this ... just tested both techniques on the spare.
Gazzerr,
The screwdriver method works like a charm, quick and yes millisecond indeed, a simple twist and the connector literally pops off. Tony's wiggling works too but takes a second or two. In addition, I like that the lever force is applied on the strongest side of the connector (see second pic) so yes, this lessens the possibility of these 30yr plastic pieces snapping off with all the wiggling, a little impatience and brute force.
Not in situ, of course.
Fun stuff, this forum is amazing, where no dog is too old to learn new tricks, right BK ? :)
http://forums.pelicanparts.com/uploa...1544412680.jpg
http://forums.pelicanparts.com/uploa...1544412689.jpg
boyt911sc 12-09-2018 08:40 PM
Test results.........
Brian,
I read your test result earlier but was not in a good mood to reply due to the Eagles’ defeat in overtime. Anyway, I got your PM too. Your test shows that the TTS is switching off too early. My previous tests showed less than 5 sec. for the six (6) TTS tested before they switch off.
If your TTS is switching off immediately after you energized it, it is defective and time to replace it. But this is only half of the test you need to do. With a good TTS, you need to physically observe the fuel delivery of the CSV too. Make sure it is not leaking and delivering strong mist-like spray pattern. However, both TTS and CSV are very robust CIS components but fail too.
You are doing a good job troubleshooting your problem.
Tony
boyt911sc 12-09-2018 08:56 PM
Troublemaker...........
Juan,
You are a provocateur and a troublemaker. You are not helping anyone by your immature posts. Instead of contributing in this Technical Forum to help and assist other people, you seem to enjoy making people get into conflict. What satisfaction do you get from your posts?
Tony
WyattEarp 12-10-2018 06:32 AM
More testing this morning.
Ambient air 55 degrees
25 ohms - WUR resistance (used by he wiggle and pull method to get connector off)
1 bar - cold pressure
1 bar - 1 min
1.25 bar - 1:30 min
1.5 bar - 2 min
2 bar - 2:30 min
2.75 bar - 3 min
3.25 bar - 3:30
3.5 bar - 4 min
So colder temps are taking longer to build pressure. Still seems to be about .5 bar low at cold start but warming steadily to a within spec warm pressure.
Also retested my thermotime switch on bench a few more times and seem to be getting proper function. So except fo having numbers I’m right back where I started.
Looking more like I’m going to have to do a drop in order to test my CSV.
Anything else I can / should test before having to go that route?
Johner 12-10-2018 07:27 AM
Have you checked timing and ignition components and verified you're getting a strong spark? This would be an easy thing to check before accessing the csv.
juanbenae 12-10-2018 08:32 AM
Originally Posted by boyt911sc (Post 10278816)
Juan,
Tony
the same satisfaction you get possibly by berating anyone who posts something you feel is not a technique of accomplishing something the way you see fit. nobody here doubts your extensive knowledge base. but on two occasions in this thread you belittled people, both pmax and gary with your replies as to how they are wrong IYO.
back to your regularly scheduled programming.
Bob Kontak 12-10-2018 09:36 AM
+1
Hope we get Wyatt straightened out.
tirwin 12-10-2018 10:55 AM
WyattEarp,
Just want to confirm something to make sure we’re on the same page. You’re describing hard/no starting when the engine is cold, right? I’m just asking because I’m wondering why you’re repeating the fuel pressures test. No harm, and it shows consistency. Just trying to understand the logic. Understand the fuel pressures might not be perfect but the cold control pressure can be near zero (really, really rich) and the car will still start.
Your condition is crank, no fire. So likely culprits would be fuel starved, air starved or weak ignition. I’ve never tried it myself on a 911 but what about a little starting fluid? If it fires up that’s pointing back to fuel starved.
Fuel related: If TTS is ok, then you have to check CSV. Check the plug to make sure it’s connected. Can you verify it’s getting 12v when cranking? That would rule out wiring problem to CSV.
Spark related: I’d pull the coil wire and check for spark quality.
Air related: Once you get the car running you say it runs fine. If you remove the oil filler cap does idle change? It should. If not you have a decent vac leak somewhere. Maybe not the root cause but probably not helping. AAV provides a little extra burp of air on start. AAR is designed to be open on cold start and closed when warm. If it was stuck closed on a cold start that would be a problem. Only way I could see that happening is if it seized.
I’m just trying to frame up how I would be starting to formulate a plan of attack to the problem.
My next stop would be the CSV.
boyt911sc 12-10-2018 11:22 AM
CSV Pressure test.........
Brian,
Performing a CSV pressure test with the engine installed for ‘81~’83 SC’s is not as easy compared to ‘80 SC’s and earlier models because of the metal fuel lines. Those CIS engines particularly ‘80 and earlier models have flexible plastic fuel lines and easy to move the CSV with the fuel line connected. You can not do this with the metal fuel lines.
So to be able to do a visual CSV flow test for your late SC with metal fuel lines, you need a special fuel hose to be able to test it. Unless you have a CIS bench tester. Removing the CSV with the engine installed is not that convenient because of its location but you can remove the CSV without removing the engine. A partial drop will help access the CSV. Once you are able to get the CSV off from its mounting by removing the two (2) Allen bolts, connect the CSV with an extension fuel line back.
I will post a picture of the extension fuel line I built to do the test or you could improvise. The key is to be able to put the CSV in a container to collect and observe the fuel delivery of the CSV.
Do a mock up operation for removing the CSV and visualize the things you need to get the job done. For example, do you need additional space for access? What tools do you need? Is it doable at the current set up? How was this done by others? These are some of the things you should be aware off.
You have not done this before and could intimidate you. It is not difficult by very tedious and cumbersome to get the CSV off and test it. Don’t get frustrated or discouraged at the very beginning. It is doable and you will succeed if you think you could do it. I have more tips to share with you.
Tony
Bob Kontak 12-10-2018 02:26 PM
I was able to pull my 81 CSV out far enough to see the spray tip with the line on.
I am almost certain I did this without a partial drop. However, I should not have as just a few inches makes a world of difference.
I place rags all around and killed the ignition.
Rigged a tripod and video camera up to capture the spray event. It was working fine.
That said, this was in my younger days when I cared not for forearm scratches and bruises. I should have confirmed that each connection point carried voltage at the right time or interfaced with ground properly before testing a very robust, yet hard to access component. (Me thinks Harry stated this many posts ago)
Side not: Just tested ohms on my 81 (090). 27 ohms. 60F on the WUR body (laser thermo) with heat on in shop. Earlier this year tested at something like 45F and it was 10 ohms. There may be something to that stepped ohms business talked about in separate threads.
Sorry about the Eagles. Cripes, the Cowboys. You should be at least a little happy the Browns won.:D
boyt911sc 12-11-2018 07:33 PM
Cold start valve removal.........
Brian,
This is how the CSV looks like installed on the motor. With your engine installed access is quite a challenge specially if you have big forearms.
http://forums.pelicanparts.com/uploa...1544583612.jpg
To get better access reaching the CSV you could do one of the following:
a). Remove the CIS boot “Pope”.
b). Do a partial drop. Or
c). Drop the motor. I don’t recommend this at this point.
Use a 4-mm Allen wrench to remove the 2 Allen bolts securing the CSV. The hollow banjo bolt for the fuel line requires a 12-mm socket or box wrench. Loosen the fuel line first before loosening the CSV and place some absorbent materials or rags to collect the gasoline that might drip during the process. Make sure you don’t lose the o-ring for the CSV.
Since you don’t have a fuel line extension you could improvise for the CSV flow test. I will update this post with the CSV installed backward for your test. For the meantime, I like to know if you could follow the procedure. We will go to the detail later.
Tony
Bob Kontak 12-12-2018 12:29 PM
I see where you are going with this. Outstanding.
Surely I stressed the metal lines to pull it out far enough to see. I would not have had to do this (with backwards procedure) but it was before Pelican that I ran this test.
WyattEarp 12-12-2018 01:59 PM
So I think I may have found my problem. Still need to get a larger sample size (more cold starts) to be sure.
Weak battery may be the issue. Apparently the car is very picky about having a very strong battery at cold start (is this a CDI thing??). The car sounds like it is cranking just as fast but fails to start. Looking back now the fail to starts have been after the car was sitting for a week or more.
I have two cold mornings in a row now with reasonably quick cold starts (say two 5 second cranks). First morning I had the car on a charger overnight after having done pressure tests. Day two was after driving the car the day before so nice full charged battery. Car actually seems and smells a bit rich when cold but given the cold pressures I am getting that is probably correct. As sooon as the car warms up a little it runs perfectly.
So this may have been a CIS thread in error. Good news is I have learned a bunch about my car and CIS thank to everyone that took the time to respond to this thread.
Bob Kontak 12-12-2018 02:46 PM
Functioning CIS engines fire instantaneously.
The strong battery masks some of the symptoms.
Not sure if you are shutting down for the winter but, if so, pull your WUR and send it to Tony for a tune up.
Walk away for a few days if needed but I still feel the cold start system needs attention.
