-   -   Looking for a step by step guide for 3.6 engine installation into an SC (http://forums.pelicanparts.com/porsche-911-technical-forum/1015183-looking-step-step-guide-3-6-engine-installation-into-sc.html)
JonT 12-09-2018 06:13 AM
With any luck my engine will be back soon after complete rebuild.
This is for a previously installed 3.6 swap into my SC.
I'm researching whether or not I should attempt this install myself or find a shop in town to install. I keep hearing how easy it is but I've gotten so close I'm worried about screwing it up myself.
The engine has been in the car running prior to the bearing issue so it should just be plug and play.
At minimum I'll understand how the install works and I'll be able to have an informed conversation with whomever does it.
Anyone have specific directions with pics and or videos? Thanks
tdw28210 12-09-2018 06:57 AM
STEP 1: Find checkbook. :)
Here's a simple overview.
3.6 Liter Engine Swap | bodymotion
Flat6pac 12-09-2018 09:22 AM
Check with Steve Timmons @ Instant G in Newark, Delaware
He has complete kits for install
Bruce
rkeele 12-09-2018 09:28 AM
+1 Steve at Instant G
uwanna 12-09-2018 09:33 AM
I'm confused, is this a reinstall of a previously installed/swapped 3.6
in your SC? If it was previously installed/swapped correctly to replace
the original 3.0, it should just be a nuts and bolts job.
JonT 12-09-2018 09:38 AM
This is a reinstall of a previously swapped 3.6 in my SC. Yes I would think it should be nuts and bolts job but like everything I take on, becomes overly complicated for my abilities! So that's why I'm trying to dig into the details of the install. Thanks
rkeele 12-09-2018 09:39 AM
It does sound like the engine was already in the car so reinstall it not hard to do, wires are color coded white to white green to green etc. you can look it up online
175K911 12-09-2018 09:58 AM
+2 for Steve Timmins. I've known him for 20+ years and has probably put together more 3.6 conversion kits than anyone else.
mepstein 12-11-2018 01:44 PM
Guys, he doesn't need a conversion kit. Engine was already in the car.
JonT - Just install step by step and ask questions as you go, the answers on this site show up in minutes, if not seconds. Just take your time and you can easily do it.
Tom '74 911 12-11-2018 05:23 PM
Here's my engine install/removal checklist for a 3.6L and my '74 911. I can almost guarantee that your's will not match mine 100%, but maybe a good place to start?
Tom
http://forums.pelicanparts.com/uploa...1544577736.jpg
JonT 12-11-2018 06:50 PM
thank you very much Tom and mepstein
3rd_gear_Ted 12-12-2018 10:13 AM
Floor jack with jack stands or four post hoist based removal?
Each scenario has nuances to address up front
JonT 12-12-2018 12:01 PM
this will be with a floor jack and some home made plywood cradle that others have done
shbop 12-12-2018 04:31 PM
Bruce
Do some research. If you don't live close enough to see Timmons in person, pass. There are many others out there.
umgang 12-12-2018 04:46 PM
You should really consult with folks who have done hundreds of them.
Steve Weiner @ Rennsport Systems and Jeff Gamroth @ Rothsport did mine and
attended to every detail. And there are A LOT of details. The excellence is in the small stuff.
Other thing to think about is the fact that with a 3.6 L motor, you will overwhelm the brakes and the suspension. So there are a few things to do to get that balance of power- braking - and handling back as Porsche intended.
That said, once it is done, it is will have you laughing maniacally and grinning ear to ear.
I've had mine for 13 years and it is still a hoot.
Nic
