Looking for a step by step guide for 3.6 engine installation into an SC
With any luck my engine will be back soon after complete rebuild.
This is for a previously installed 3.6 swap into my SC.
I'm researching whether or not I should attempt this install myself or find a shop in town to install. I keep hearing how easy it is but I've gotten so close I'm worried about screwing it up myself.
The engine has been in the car running prior to the bearing issue so it should just be plug and play.
At minimum I'll understand how the install works and I'll be able to have an informed conversation with whomever does it.
Anyone have specific directions with pics and or videos? Thanks
1980 911SC Targa 3.6L
Old 12-09-2018, 06:13 AM
Cars and Cappuccino
tdw28210's Avatar
STEP 1: Find checkbook.
Here's a simple overview.
3.6 Liter Engine Swap | bodymotion
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 12-09-2018, 06:57 AM
Check with Steve Timmons @ Instant G in Newark, Delaware
He has complete kits for install
Bruce
Old 12-09-2018, 09:22 AM
rkeele's Avatar
+1 Steve at Instant G
Old 12-09-2018, 09:28 AM
I'm confused, is this a reinstall of a previously installed/swapped 3.6
in your SC? If it was previously installed/swapped correctly to replace
the original 3.0, it should just be a nuts and bolts job.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 12-09-2018, 09:33 AM
This is a reinstall of a previously swapped 3.6 in my SC. Yes I would think it should be nuts and bolts job but like everything I take on, becomes overly complicated for my abilities! So that's why I'm trying to dig into the details of the install. Thanks
Old 12-09-2018, 09:38 AM
rkeele's Avatar
It does sound like the engine was already in the car so reinstall it not hard to do, wires are color coded white to white green to green etc. you can look it up online
Old 12-09-2018, 09:39 AM
175K911's Avatar
+2 for Steve Timmins. I've known him for 20+ years and has probably put together more 3.6 conversion kits than anyone else.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 12-09-2018, 09:58 AM
The 9 Store
Guys, he doesn't need a conversion kit. Engine was already in the car.
JonT - Just install step by step and ask questions as you go, the answers on this site show up in minutes, if not seconds. Just take your time and you can easily do it.
All used parts sold as is.
Old 12-11-2018, 01:44 PM
Tom '74 911's Avatar
Here's my engine install/removal checklist for a 3.6L and my '74 911. I can almost guarantee that your's will not match mine 100%, but maybe a good place to start?
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 12-11-2018, 05:23 PM
thank you very much Tom and mepstein
Old 12-11-2018, 06:50 PM
3rd_gear_Ted's Avatar
Floor jack with jack stands or four post hoist based removal?
Each scenario has nuances to address up front
1980 911 - Metzger 3.6L
2016 Cayman S
Old 12-12-2018, 10:13 AM
this will be with a floor jack and some home made plywood cradle that others have done
Old 12-12-2018, 12:01 PM
shbop's Avatar
Bruce
Do some research. If you don't live close enough to see Timmons in person, pass. There are many others out there.
Jon
Old 12-12-2018, 04:31 PM
You should really consult with folks who have done hundreds of them.
Steve Weiner @ Rennsport Systems and Jeff Gamroth @ Rothsport did mine and
attended to every detail. And there are A LOT of details. The excellence is in the small stuff.
Other thing to think about is the fact that with a 3.6 L motor, you will overwhelm the brakes and the suspension. So there are a few things to do to get that balance of power- braking - and handling back as Porsche intended.
That said, once it is done, it is will have you laughing maniacally and grinning ear to ear.
I've had mine for 13 years and it is still a hoot.
Nic
911S/GTS4
964 C4
1987 Carrera 3.2
Old 12-12-2018, 04:46 PM
