-   -   NLA main bearing set - can anyone inform where to find? (http://forums.pelicanparts.com/porsche-911-technical-forum/1015348-nla-main-bearing-set-can-anyone-inform-where-find.html)
AlexJ 12-11-2018 07:09 AM
Hi!
I have the cases of a 2.7 74 re-aligned and after the job done, measurements show that I need a set of main bearings oversized +0,25 (outer oversize). Crank is still STD.
From my search , the set I need is part number 91110190160 but I cannot find it any where....
Our host only sell a set, under the same reference, with number 8 bearing which I don’t need because it remained STD.
Does anyone knows a supplier for these?
Thanks in advance for any help.
shoooo32 12-11-2018 07:47 AM
You can always give EBS (Engine Builders Supply) a call. They're pretty much the go-to guys for all things Porsche engine.
Steve F 12-11-2018 07:57 AM
Yup, those guys:<)
https://www.ebsracing.com/
eastbay 12-11-2018 08:15 AM
I bought a set from the local Pcar dealer.
AlexJ 12-11-2018 08:45 AM
Thanks for your help!
cmcfaul 12-13-2018 11:58 AM
Gonna be expensive. Don't know why but they are. For me it was cheaper to get a standard crank. Guess you cant do that if your case is the colporate.
Chris
