NLA main bearing set - can anyone inform where to find?
Hi!
I have the cases of a 2.7 74 re-aligned and after the job done, measurements show that I need a set of main bearings oversized +0,25 (outer oversize). Crank is still STD. From my search , the set I need is part number 91110190160 but I cannot find it any where.... Our host only sell a set, under the same reference, with number 8 bearing which I don’t need because it remained STD. Does anyone knows a supplier for these? Thanks in advance for any help.
K-Jetronic student
You can always give EBS (Engine Builders Supply) a call. They're pretty much the go-to guys for all things Porsche engine.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
I bought a set from the local Pcar dealer.
Thanks for your help!
K-Jetronic student
Gonna be expensive. Don't know why but they are. For me it was cheaper to get a standard crank. Guess you cant do that if your case is the colporate.
Chris |
