Harlan Chinn's Avatar
Porsche Crest Tire Valve Stems
Ok, I now have new fuch rims and tires. What kind of valve stems should I have installed? Inexpensive rubber stems? Metal valves stems? What about the metal valve stem supports? Are they absolutely necessary? Advice Opinions?
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 03-10-2003, 08:56 PM
MIK911's Avatar
I've heard the metal stems have a tendency to leak. I didn't care for the look of long rubber stems on my polished lips on my Fuchs, so i got the SHORT stubby rubber stems with chrome housing. With it's shorter length, i don't feel a stem support is necessary.
How are your fuchs finished? Lets see some pics.
Can't see the stems on this pic, but chrome valve stem sleeves blends in with polished lips.
Mike
'86 coupe
Old 03-10-2003, 11:31 PM
Bill Douglas's Avatar
Mine are just the super short stubby ones for motor bikes. they definetly don't need ant support as theey are so short.
Harlan, whats all this "Location: 47.36 N 122.20 W" Have you just got yourself a GPS and having fun playing with it
Old 03-10-2003, 11:49 PM
Get motorcycle stems. They are less than 1" long, rubber. You don't want to screw metal stem into that nice aluminum rim, and leave marks.
GeorgeK
Old 03-11-2003, 12:15 AM
Wavey's Avatar
I don't know, you guys might be surprised how much centrifugal force can bend even short stems on the wider wheels where they mount more horizontally. My '88 Carrera had some short stems on it, 1" to the base of the cap, with no stem supports, when I bought it - one of them had a split that only leaked at higher speeds. You could drive forever at 50 or so, but it would leak down at anything faster.
That being said, brand new, REALLY short stems would probably be OK without the supports.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 03-11-2003, 04:48 AM
To add another point to the topic, PCA requires metal stems for Club Racing and Michelin strongly recomends them with a proper metal cap for track use. Have you ever touched your rim after spirited or track driving? It's pretty darn hot. In fact, I've seen the plastic valve caps melt onto the stem...yikes. Many tire deflation problems stem from...well, you guessed it...
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 03-11-2003, 05:11 AM
Super Moderator
cstreit's Avatar
I use metal stems in the racecar and have not had an obvious leaking problem, then again, I adjust constantly.
IF you use the rubber ones, try and use the short stems. If you use rubber, try and use the supports. THe force on them at higher speeds can bend and split them...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-11-2003, 05:34 AM
Automotive Writer/DP
Randy W's Avatar
I agree with Chris, for wheels that are used tracking or autocrossing, I use metal valve stems.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 03-11-2003, 06:06 AM
Porsche Crest Fuch Photo
Here is a photograph of one of the front wheels. I am doing 7 and 9's. You can see rest of the project car if you search "Pacific Blue".
Harlan Chinn
Old 03-11-2003, 07:05 AM
Bill Verburg's Avatar
I agree w/ all those that recommend metal stems. But I would also add that you should also use the metal caps with seals. The Forces on the stem can actually compress that little spring inside the stem releasing air to atmosphere.
Bill Verburg
Old 03-11-2003, 12:18 PM
Wavey's Avatar
MIK911:
I'll give you $500 for that old VW in the background.
Your friend, Wavey
Old 03-11-2003, 01:26 PM
