If you crash that hard I highly doubt having the spare in there is going to make any difference to your well being
Rocker Delete for Weight Loss?
Here are a couple of threads on deleting the rockers.
Tips for rocker panel delete in a 911 3.2 Impact bumpers without rocker covers ? |
Rsd.
pm sent.
Gerry |
Before buying current car, test drove a chipped 86 Carrera Street/track car stripped of all sound deadening, super lowered with a competition suspension, integrated roll bar, etc. After driving it for 5 mins the enjoyment of a fastish car was trumped by how noisy, stiff and generally uncomfortable it was. Passed on it immediately since am not a fan of ear plugs and back aches. What a wimp. Removed my engine sound pad but left the rest. |
that is why I also have a 928. :cool: |
1) I think the "spare tire/crush zone" notion is an urban myth. At one point a lot of PCA regions required that the spare be in place for that ostensible reason, but it isn't going to deform. On a 356, due to its position, it might prevent some penetration, or spread deformation over a larger area. Not so in our 911s. My wife had a racing wreck (other driver's stupid mistake)which shoved the front right back so far that the wheel was jammed against the front door jamb, and the floor pan distorted like mad. The fuel tank was pulled from its mounts and moved backward, but not damaged, though. The tire just sat there.
2) I liked being able to adjust my outside mirrors while driving. I miss being able to do that, and needing someone to adjust for me before I go out on the track if the right side is wrong (left, for that matter, if strapped in with window net). Similarly, I wish I had power windows. To be sure, I race in a class where I need a bit of weight after much else has been removed. But it is nice to be able to raise and lower windows from the driver's seat. Yes, I hate the wiring, and have not figured out a connector system which allows removal of the mirror alone, or of the door, without a whole lot of wiring aggravation. But if that is solved, what's not to like about this sort of cockpit convenience? |
Removing weight is easy and adds power to weight ratio. Removing 8kg (17.5LB) corresponds to 1HP isch. So by removing 500lb it feels like you've gained 30HP. Car is incredibly light in the corners and needless to say also on the brakes. So go for it. Just remember: It's easy to remove weight on a 911, but hard to make it look nice! |
Nothing beats removing weight for added performance. -8kg may equal 1hp but adding 1hp doesn’t offset 8kg. All the horsepower in the world can’t make a heavy car feel light. |
| All times are GMT -8. The time now is 11:07 AM. |
