Wait a minute. How the heck are you supposed to jumpstart a 911 ?
I've never jumpstarted my 911.
If the battery went dead, I'd just connect a battery charger. My charger has tiny little clamps, and I never thought much of it. Now, I own one of those jump packs. https://cdn7.bigcommerce.com/s-wh2t0...=2&imbypass=on I tried to use it today. There is no way the full size clamps could fit down under the fender. Which begs the question, how the heck have you ever jumpstarted with jumper cables and clamps???? There is absolutely no room down there to fit a large red clamp. http://i65.tinypic.com/25qu2vn.jpg |
I am now noticing the different batteries have the posts on different sides.
Contrast these two. The Bosch would have the red post on the INSIDE of the car, away from the fender. Ther other would have the red post on the OUTSIDE of the car, under the fender. https://4.imimg.com/data4/IF/VY/MY-1...ry-250x250.jpg https://images-na.ssl-images-amazon....dL._SY355_.jpg |
Lay the clamp down and slide it on. Or lock a pair of vice grips on the battery clamp and clamp the jumper to it. Use your imagination.
Easier to push start!
+1
I tried every angle, obviously. I love the Vice grip idea ! Quote:
There is no slack in the cables to stay connected to the battery. So, when you say "pull the battery", am I jump starting the naked battery cables with the unattached battery sitting on the ground? Can a car run without a battery attached? Do you reattach the battery to the cables while the car is running? |
you will fry the alternator if you run the car without a battery. Are the cables so short you cannot slide the battery forward? It does not look like the terminals are correct for a Porsche, they should be on the other side. If the car can move a push start in 3d gear with ignition on is very easy.
Or put a charger on the battery and start it after its charged. |
As on many of my cars and motorcycles , I just add a jump wire to the + post and pull it into service when needed
Merry Christmas |
Keep a small needlenose visegrip in your tool kit. Clamp it on the + terminal clamp and attach the jumper to the visegrip.
I bought one of these for every car, Porsche and non-Porsche. Works great.
TOPDC Jumper Cables with Quick Plug 1 Gauge 25 Feet 700Amp Heavy Duty Booster Cables (1AWG...) For now mine are hooked up to the battery up front. When I re-wire the charging cables and cables to the starter motor the plug will be connected to the starter motor and the plug in the engine compartment. Merry Christmas to all, and too all good jumping! |
There's a thread on how to jump a 911? Now I've seen it all in the Tech Section.
http://forums.pelicanparts.com/support/smileys/wat3.gif |
It falls in line with most of sugarwood's threads... |
Then put the negative on the bolt above. |
Good grief Sugar. Is everything in your life difficult?
Super easy to push start. Just like a bug!
this is brilliant and exactly the kind of thing that would make jumping (or charging) a 911 super easy. |
My charger has a quick connect.... most do. I also have a long lead with typical battery charging clamps to jump the car if necessary.
You'd have to seal off the open connection somehow. With that, you could just use traditional jumpers snice the (-) post is not blocked. https://www.amazon.com/Spartan-Power-Gauge-Battery-Cable/dp/B0713MGL78?th=1 Then again, Walker's vice grip trick accomplishes the same thing for free. |
Sugarwood -- while I don't have the same jumper set as you, I've had no real issue using several sets of jumper cables on my 911 battery - could be the orientation of the positive cable? My 911 is currently at the body shop, but if I recall correctly, the bold that secures my positive clamp to the battery was oriented toward the front of the car, allowing me to (relatively) easily clamp across the bolt on the positive terminal.
Good that you did a dry run with yours before getting stuck "in the wild" -- do you have other cables that you could also try? This may be specific to the new cable set you just bought/received (?) |
You're such a tool. Next you'll be asking how high the car has to be off the ground to change a tire.
"Wait a minute..." Your best bet is to call Triple A. They'll have you jumped and on your way before you figure it out. |
Go check your battery. The (-) terminal should be towards the front of the car. The (+) cable does not have enough slack to reach the front of the car. The only thing I can think of is that your battery posts are transposed. Is your (+) terminal on the inside or outside ? As you can see in post #2, both styles are manufactured. If the post is on the inside of the car, closer to the gas tank, then it is not blocked by the fender. |
Not one had terminals blocked like this. It's obvious you don't grasp the gist of this conversation. Kindly get lost. Better yet, put me on ignore and FOAD. |
Do you think you're going to rest it on the gas tank? Sorry, no slack. Do you think you're just going to hold it in mid-air ? Sorry, you need to go turn the key. On a 911, you can not move the battery while the (+) cable is attached. |
To your question of charging.....I have a battery tender brand charger, and have their wire attached to the battery cables with ring connectors. When the car comes in I just plug the plug into the wire for the battery tender. This allows me to charge/top up the battery just bu opening the trunk and attaching a 1 way plug. Simple. I use the cables I sited earlier for jump starting only. I have found this to be about the best setup. |
a jumpers set with a quick disconnect in the middle like you shared would have been excellent. my thought for jumping/charging is that an additional connector could be wired to the end of the charger and then all aux electricity would be channeled the same way. |
Can somebody post a picture of their battery in their car?
The underlying assumption in the OP's post is that all batteries in 911 are configured like this. Maybe some pics would help. Sugarwood, have you loosened the hold down clamp and tried to move the battery towards the center line of the car? Your picture is not clear on the positive end of the battery with respect to clearance. Something is wrong with the battery placement or size. OP's picture shows no access to positive terminal. If this were the same across all 911's there would have been products made to remedy by now. |
Now, these 4 kids weren’t from the KINDAI University but had come there on another event. Battery dead, they flagged me down and it was odd and suspicious. They asked me if I had jumpers, I said oh yeah, but they are in my garage at home. Oh! They said, don’t worry, we’ll just ask the next person that comes by. I paused, knowing that no car would come by on that dark thin street after 9:30 at night. Long story short, I said show me the battery, then I took my battery out of my van with my tools within two or so minutes. Took it over to the car, told one student to shine his iphone light on the batteries, another to hold the battery sideways, A third student I told to hold the key in the car on start position wherein I simply put two spanners on the posts both ways positive and negative. As soon as I did the car started and the kids were over the moon. I had my battery back in my car within two minutes and was on the road. The whole ordeal might have lasted 10 minutes from the time I was stopped to the time I shipped off. Now that is how you start a f-cking car! I just had to share this true story after seeing this thread for the first time. Bernard |
No, I did not loosen the battery. Why? I simply attached a trickle charger and went to bed. The next morning, I went for a nice long XMAS drive across state lines. I will try moving the battery, to see if the clamps then fit, for the sake of documenting this archive. But, the premise of starting this thread was to figure out how 1000's of 911 owners have jump started their cars "in the wild" over the years. My assumption is that you will not have an extension bar and hex socket bit to move the battery. So, as it sits, it's impossible on the road with only jumpers. So, your other questions are the crux. I use a size 48 battery. Pretty standard. Maybe AGM batteries have their posts inverted to the outside? I would love to see photos of other 911's battery bays. How many people here can attach standard clamps to their (+) post? Snap a photo and maybe we can get to the bottom of this mystery, as Bob posed. Quote:
1st I understand the question as there are many folks in this world that are not real handy or lack hands on experience(not me)
I can tell you that over the ownership of 6 different 911s I had on occasion had to jump start one of them.. I never found it to be difficult. Just had to lay the clamps at a 45 degree angle.. |
Here’s my battery set up- I believe it is the “factory” large size Interstate replacement. I do have aftermarket ends with posts from my car stereo days and could probably get jumpers on the terminals, although I can’t remember every giving or receiving a jump in 28 years of ownership- I know there were a few push starts over the years.
http://forums.pelicanparts.com/uploa...1545928112.jpg |
| All times are GMT -8. The time now is 07:23 PM. |
