torque specs for rotor bolts
Hey all, does anyone know what the torque figures are for the bolts that hold the rotor to the hub? my car is a 78 SC. many thanks.
Kyle. |
Irrationally exuberant
What bolts? I thought there were just a couple of little screws (6x12mm)?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
sorry, the front rotors, not the rears.
It'll be legen-waitforit
Kyle,
This brings up a great point; someone out there must have a spreadsheet of all the torque specs or a good compilation of one. I would love to keep one in my glove box so I don't have to come and search Pelican every time. Who's the smart cookie?
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Senior Member
Kyle, I did not look it up, but discussed it with JW. He agreed that 18 lb/ft sounds correct, assuming Grade 8 bolts. For rotors, Grade 8 sounds appropriate, and that's probably what comes stock. See if there is an 8.8 cast onto the bolt heads.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Superman,
Bolt grades seems to be one of those "Ponderable " things. I believe that 8.8 is a metric designation for high strength bolts and it corresponds to a SAE 5 (3 ticks on head) bolt. A metric 12 is equivalent to a SAE 8 (6 ticks on head) bolt. I can't find the link but somewhere on the web is a great page that explains more than you ever wanted to know about high strength bolts. Anyway, did you resolve your spark saga?
thx Jim, 18 it is! i'll get that done tonight hopefully !!!
18ft/lb is right. I checked the Bentley manual, it' 17lb.
Caliber 1987 911 Cabriolet |
Standard M8 DIN 8.8 bolts and nuts ... calling for the standard torque of 25 Nm or 18 lb-ft. I guess a rounding error is in effect in Bentley!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
