Bad idle SOLVED
Simple fix but gives me a little confidence in making this car a dependable driver.
1973.5 911T ——-1974 914/1.8 |
Still here
Sorry... what are we looking at above and which engine (SC/3.2)?
was installed backward, the reason that the underside of the air filter element is beat to crap. And looks like I have a split airbox too, but the engine runs nicely.
73.5 T No clue why the photos are turned 90*
Reiver
If the underside of your air filter is 'beat to crap' then you have been backfiring.....did the pop off leak prior to the backfires or did they mess your box up.
Hate them or love them....mine, properly installed...has saved my box on two occasions in 3 years now....idles fine, runs great even after those two backfires.
De Oppresso Liber Strength and Honor 5th Legion |
The engine has ran perfectly, no backfires until recently when the fuel pump started to intermittently stop working, then I experienced a couple of backfires and rough running. The car came with a damaged K&N air filter that I plan to change. The P.O. didn't throw away the original fuel pump, I tested it on the car and works fine except a fuel leak around the electrical terminals. I've sent it off to the rebuilder in CA. that was recommended on this forum. I'm sure my airbox is broken, most of the screws are stripped but the engine seems to not mind. Clutch change in the future that I plan to do the airbox and address a few oil leaks.
1973.5 911T ——-1974 914/1.8 Last edited by Artfrombama; 12-29-2018 at 12:26 PM.. |
The forum software automatically aligns the photos in landscape mode so that the long edge is always horizontal; obviously not an easy thing to change.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Functionista
Choosing the “square” option before taking a picture solves it.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Fleabit peanut monkey
I don't know anything more about this. Just a heads up.
1981 911SC Targa |
