Got Boost?
My 911 C3's rear end is currently dismanteled. No engine, transmission, or suspension components on the rear end. I need to get the car on a Flat Bed truck to transport it to a welder that will be fixing my torsion bar tube. My mechanic said that he would mount the bannana arms, torsion bars, and spring plates. He said this would be enough, no shock absorbers and no transmission and half-shafts.
I just wanted to ask if this is fine and will cause no damage on a 1 hour and a half trip on a flat bed.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work." -Ayrton Senna- |
no shocks isn't be a problem, technically you could drive the car like that. I would think it would be ok without the half shafts and tranny, but someone else will probably verify that.
Only the torsion bars, banana arms, and spring plates are needed. Without an engine the suspension will not be compressing at all anyway.
Author of "101 Projects"
Sometimes even less than that is needed - don't ask me how I know...
![]() -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Got Boost?
Thanks guys! I won't worry about it then when they take it away then.
