Time-sert question
My locking bolt for the speedometer drive shaft on my 68 transmission is stripped. I have been using time-serts and I’m very happy with them compared to helicoils. My problem is the M8 x 1.25 kit standard insert length is 11.65mm. The depth of the hole is about 10.2mm. Time-sert sell a 9mm long carbon steel insert and an 8mm long stainless. I am concerned the 9mm may be to close to the end and could blow out what I believe is a mag case. Not sure about stainless and mag. I’m considering cutting an insert I have, I realize I will loose the locking feature, I would just loctite it in. There is no rotational force on this bolt/pin. Suggestions/comments.
Old 01-13-2019, 08:16 AM
I have cut Time serts many times to work in situations like this
You will lose the locking feature but I think you'll be fine
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 01-13-2019, 09:48 AM
Agreed. I’ve set them successfully with locktite.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 01-13-2019, 10:27 AM
Thanks guys, appreciate the feedback. That’s what I will do.
Old 01-13-2019, 10:44 AM
