front fender and cowl seals
Hi,
I have a 964 and am looking to replace the rubber seals that go between the top of the fender and the cowl with a wider then stock version. Does anyone know if they make this product and where I can buy it?
Thanks,
Old 01-13-2019, 03:55 PM
It's called welting you can buy it here on pelican.why would you want thicker than stock???
Old 01-14-2019, 04:44 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Just more forgiving. They are not thicker on the mating surfaces just the visible part. Inconsistencies of fit are better masked.
Does Pelican have the wider ones? Pretty sure I bought mine from here in the way back.
1981 911SC Targa
Old 01-14-2019, 05:50 AM
Thanks guys.
Someone painted the cowl and fender without removing it. I want to remove the old ones, wet sand, polish and then replace with wider version to hide any sins.
I saw 2 versions 4.3mm and 6.5mm (1/4”). What was the width when new? Anything wider then 6.5mm?
Old 01-14-2019, 09:51 AM
joefrantz's Avatar
Looks like both sizes are still available.
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=Fender+cowl+seal
Joe Frantz
73 911 T
Old 01-14-2019, 10:26 AM
Good to know thanks bob.
Old 01-14-2019, 11:50 AM
small piece of welting to be replaced
It is possible to buy a small piece of welting? Or is there a welting part specific to the area shown in the picture where its missing?
Old 12-18-2020, 03:52 PM
Should be one of the ones on this page:
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=seal+fender+extension
Old 12-18-2020, 10:03 PM
Location: behind the redwood curtain, (humboldt county) california
While yoou are in there....
While you are in there, check for frunk gutter rust around/under the weatherstrip for the hood. You could feel along the underside of the frunk gutter for any roughness, possibly indication rust through.
I had some serious perforation, which allowed rain to soak the passenger floor carpet.
On a similar note, i found rust through between the L fender and the body of the frunk. Water from above and below.
Good Luck,
chris
You really don't want to see the pictures :-(
Old 12-19-2020, 09:54 AM
Seal - Fender Extension Panel
On the right track! I dont see left front LOWER. Wondering if upper means both upper.. same one fits upper and lower of that panel.
Old 12-19-2020, 06:51 PM
Titanium User
Lower seal fender extension 911 503 325 00
https://www.pelicanparts.com/More_Info/91150332500M350.htm?pn=911-503-325-00-M350&bt=Y&fs=0&SVSVSI=911M
Originally Posted by jgurnari View Post
on the right track! I dont see left front lower. Wondering if upper means both upper.. Same one fits upper and lower of that panel.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 12-19-2020, 08:48 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
This is a known problem in the Porsche parts catalog. The front piece has been incorrectly superceeded to the incorrect part number..
Marc
Old 12-19-2020, 09:49 PM
The upper and lower are different, but left and right are the same ( just flip them over).
Lower is shorter and has shallower curve. Should be there somewhere.
Old 12-19-2020, 10:26 PM
Front welding in catalog
Mark are you saying that the part in the catalog IS the lower, which is what im looking for, but the part number is incorrect? It does say upper on all those parts. Thanks
Old 12-20-2020, 05:19 AM
each side is the same...but
I understand each side are interchangeable but I am missing the lower on the left side. and need to buy one...Obviously if i move the right to left I will be missing the right side! Thanks
Old 12-20-2020, 05:22 AM
911 503 326 is the upper. 911 503 325 is the lower. The link in dg567's post #11 is what you need.
_______________
John
1988 Carrera Targa 3.2 G50 - Sold.
2017 Chevy Silverado K1500.
Old 12-20-2020, 06:21 AM
Sorry, I misunderstood...I thought you could find only one side on the Pelican site... I was just saying, but two of the same b/c they're the same.
Btw, as stated above the link in post #11 is definitely the right one.
Old 12-20-2020, 12:46 PM
That’s great thanks all!!
Old 12-20-2020, 06:25 PM
