Another harness question
What is the collective wisdom regarding the need for a harness bar in a car with slotted seatbacks that aren't necessarily FIA seats-I'm thinking of the DAD's and similar?
You don't mention what year you have. But, a five point harness is quite dangerous to use with out a "harness bar" device, either that or a roll bar or cage. If you only bolt the belts to the floor boards, on impact the shoulder harness's collapse or crush down on the spine, very bad. The harness bar provides the correct angle for the belts to hold rather than squish you. A harness bar provides nothing more than a place to route belts over.
1991 964 C2 -SOLD - miss it everyday - ![]() 2009 Honda CRV 2007 Audi A4 Quattro - just a sweet personal car - 2000 Land Rover Disco II - lifted 2001 GMC Seirra 1500HD CREWCAB |
I understand the principle behind the need for a harness bar. However, I'm given to believe that with an FIA certified race seat, at least, the bar becomes unecessary as the downward loading can't occur. I'm just wondering if there is any opinion regarding whether the same thought process works for non-certified seats, at least in a car that only sees DE type action.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Non Compos Mentis
A harness bar is much cheaper than back surgery.
Irrationally exuberant
You are doing the right thing asking and researching this for yourself. I was told by a shop that sells harnesses and helmets that it was OK to attach the harnesses directly to the harness bar (a big no-no) so even seemingly knowledgeable vendors may be ignorant. -Chris |
A secondary question here: Is there a harness bar available for Targas? It seems they are all designated for coupes.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
-Chris |
