-   -   space between bilstein inside boge strut (http://forums.pelicanparts.com/porsche-911-technical-forum/1018095-space-between-bilstein-inside-boge-strut.html)
deftom 01-14-2019 10:40 AM
Hi guys :),
I was working on my boge strut and put a bilstein shock absorber inside...
and I was wondering if this little space is normal? Did I miss something??
Thanks a lot:)!
Have a nice day
http://forums.pelicanparts.com/uploa...1547491215.jpg
cdrik915 01-14-2019 10:49 AM
If i'm correct , Bilstein must be mounted in Bilstein strut.
deftom 01-14-2019 10:51 AM
Nop monsieur, bilstein existe for boge strut
75 911s 01-14-2019 11:01 AM
The gap is normal. I did this to my 75 last year and I ran into the same question.
The gland nut literally dead stops a few mm from the top. I did run into an issue where one side came loose. I believe it may have been the safety washer wasn't bent over all the way on the top nut on the insert (in the frunk). Causing it to rotate a bit and get loose.
deftom 01-14-2019 11:03 AM
So it seem's to be norma! Thanks a lot :)
75 911s 01-14-2019 11:07 AM
Here are some photos if you want.
- starts about half way down the page.
deftom 01-14-2019 11:14 AM
Exactly the same thing! Perfect :)! Thank you very much
mepstein 01-14-2019 01:11 PM
Yes, normal and correct. - I called Bilstein about the first set I did and they confirmed.
deftom 01-14-2019 09:44 PM
great thank you :)
Lyle O 01-16-2019 03:43 AM
It helps too if you use the gland nut tool Bilstein makes for this. If you call them or send email you can buy one (they used to be free). $12 I think. This will allow you to put some good torque on the nut without scratching it up (like if you use a pipe wrench, for example).
deftom 01-16-2019 04:48 AM
Thanks for this information.
Unfortunately, I already tightened the nut with a vise-grips. As you said, it makes some scratch on the nut...
But it doesn"t seems to be a big deal.
JMT 01-16-2019 05:00 PM
This is a electrical coupler I got at Home Depot that I ground down with an angle grinder. I can get a big pipe wrench on it now. I just hope the little lugs don't break off.
http://forums.pelicanparts.com/uploa...1547686673.jpg
http://forums.pelicanparts.com/uploa...1547686725.jpg
http://forums.pelicanparts.com/uploa...1547686762.jpg
deftom 01-17-2019 09:27 AM
Fantastic !!!!!!! Unfortunnately, I don't have your skill nor your tool.
By the way, I 'am rebuilding the front wheel axel unit... as you can see, it was not useless ;) !!
http://forums.pelicanparts.com/uploa...1547746033.jpg
JMT 01-17-2019 10:22 AM
If your rebuilding your front suspension you have the skills my friend.
mepstein 01-17-2019 11:29 AM
I use my spanner wrench to tighten. Available at most bike shops for around $15
