space between bilstein inside boge strut
Hi guys
,I was working on my boge strut and put a bilstein shock absorber inside... and I was wondering if this little space is normal? Did I miss something?? Thanks a lot !Have a nice day
If i'm correct , Bilstein must be mounted in Bilstein strut.
LIGHTER = FASTER !!! |
Nop monsieur, bilstein existe for boge strut
Registered Minimalist
The gap is normal. I did this to my 75 last year and I ran into the same question.
The gland nut literally dead stops a few mm from the top. I did run into an issue where one side came loose. I believe it may have been the safety washer wasn't bent over all the way on the top nut on the insert (in the frunk). Causing it to rotate a bit and get loose.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
So it seem's to be norma! Thanks a lot
Here are some photos if you want. - starts about half way down the page.
Exactly the same thing! Perfect
! Thank you very much
The 9 Store
Yes, normal and correct. - I called Bilstein about the first set I did and they confirmed.
All used parts sold as is. |
great thank you
It helps too if you use the gland nut tool Bilstein makes for this. If you call them or send email you can buy one (they used to be free). $12 I think. This will allow you to put some good torque on the nut without scratching it up (like if you use a pipe wrench, for example).
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Thanks for this information.
Unfortunately, I already tightened the nut with a vise-grips. As you said, it makes some scratch on the nut... But it doesn"t seems to be a big deal. |
This is a electrical coupler I got at Home Depot that I ground down with an angle grinder. I can get a big pipe wrench on it now. I just hope the little lugs don't break off.
Fantastic !!!!!!! Unfortunnately, I don't have your skill nor your tool.
By the way, I 'am rebuilding the front wheel axel unit... as you can see, it was not useless !!
If your rebuilding your front suspension you have the skills my friend.
The 9 Store
I use my spanner wrench to tighten. Available at most bike shops for around $15
